Homework Help: Error and significant figures
  1. Jul 14, 2016 #1
    We measure the period of oscillation of a simple pendulum .In successive measurements ,the readings turn out to be 2.63 s , 2.56s , 2.42s , 2.71s and 2.80s . What is the period of oscillation taking into account appropriate significant figures ?
    2. Relevant equations
    3. The attempt at a solution
    Mean period of oscillation T = ( 2.63 + 2.56 + 2.42 + 2.71 + 2.80 ) / 5 = 13.12/5 =2.62s
    Arithmetic mean of absolute error ΔT = ( 0.01 + 0.06 + 0.20 + 0.09 + 0.18 ) /5 =0.11 s
    This gives time period = 2.62 ± 0.11s
    But , since the arithmetic mean is 0.11 s there is already an error in the tenth of a second . Hence there is no point in giving the period to a hundredth .
    Now , my doubt is whether time period should be expressed as (2.62 ± 0.11s) OR (2.6 ± 0.1s) .
    Thanks
  3. Jul 15, 2016 #2
    BvU
    2017 Award
    You have five observations; average is 2.624, estimated standard deviation ##\sigma## is 0.15 (excel stdev.s), so the estimated standard deviation in the 2.62 is 0.065 (##\sigma_m = \sigma/\sqrt N##) .
    The relative accuracy of ##\sigma## is ##1/\sqrt 5## so about 50%. Your best shot is ## \ 2.62 \pm 0.07 ## seconds.
    Aside from that:
    Numerically, you ended up with an error estimate with first digit 1. I learned that in such a case one gives two digits since the step (0,1,2) is too big. But: With only five observations there is a lot to be said in favor of giving only one digit anyway.
    And another aspect: if you are going to do something with this result (plot T as a function of some length, calculate g, etc.), the remainder of your expose will be easier to follow with 2.62 +/- 0.11 than with 2.6 +/- 0.1 . And if you don't leave out mentioning the number of observations, a good reader understands.
    Somewhat a matter of taste; I'd love to read other arguments. Any takers ?
  4. Jul 15, 2016 #3
    haruspex
    My view is that rounding to some number of digits in order to indicate the accuracy is merely a way to imply the range when no other indication is provided. If you are going to specify a range explicitly, you can, and should, show more digits for the best estimate (usually the middle of the range).
    I didn't understand the remark about relative accuracy. Isn't it just a question of deciding how many standard deviations constitute a +/- error range? Two or three, maybe?
  5. Jul 15, 2016 #4
    BvU
    2017 Award
    I learned (yes, long ago...) that if you report only a +/- Δa then that's the sigma. If you want to report a range then that can be 2 or 3 sigma, but then you include a confidence level (e.g. 95% C.L) .
    The relative error remark was on the relative error in the estimate of ##\sigma## from a sample. It is ##\approx 1/\sqrt N##. You need a sample size of 10000 to get an error of 1% in the ##\sigma## !
    Life becomes even more inteesting if you have a systematic error to report; you can fold it into the statistical error, but you can also write a ##\pm## Δastat ##\pm## Δasyst (syst) which looks really professional
  6. Jul 15, 2016 #5
    So which of the two , (2.62±0.11)s OR (2.6±0.1)s seems better ?
  7. Jul 15, 2016 #6
    haruspex
    The first.
  8. Jul 15, 2016 #7
    From the OP :
    Do you mind explaining why you didn't like the above reasoning ?Please explain as simply as possible .
  9. Jul 15, 2016 #8
    haruspex
    It doesn't hurt to show the extra .01s, and it is closer to the truth. If you write +/-0.1s then you are not quite encompassing the range. But to write +/-0.2s would be unnecessarily cautious. Maybe you think that +/-0.1s should be interpreted as per the sig figs convention, i.e. as really meaning +/-(0.1+/-.05), but that just gets silly.
    Suppose you had computed the error range as +/-0.123. In that case, I think it would be reasonable to write it as +/-0.13. The extra 0.007 is insignificant, and it does encompass the computed error range.
  10. Jul 16, 2016 #9
    Tom.G
    Since you are trying to get a handle on measurement uncertainity, here's a link to a somewhat dated version of the international standard.
    I haven't checked lately, there may be a later version. NB. It's about 7 megabytes zipped.
    GUM - Guide to expression of uncertainity in measurement2008 & Intro & Supplement 1
    URL: http://www.bipm.org/utils/common/documents/jcgm/JCGM_pack_2010-03.zip [Broken]
    (My download Date was: 2011/02/14 15:00)
Have something to add?
Draft saved Draft deleted
Loading...
