Homework Help: Error checking in C
  1. Mar 19, 2012 #1
    I have the following chunk of C code that checks for errors. Works fine but I don't understand why it works.
    Code (Text):
    printf("\nEnter the number of students\n");
    valid_input = scanf("%d", &snum);
    if(!valid_input){
       printf("\nInvalid number of students\n");
       system("pause");
       return 1;
    The condition of the if statement is confusing me. From what I understand it is returning true if valid_input is false then terminates the program with an error code. What makes valid_input false when I type characters in it? Do all variables become false when there is data of the wrong type stored in them?
  3. Mar 19, 2012 #2
    http://msdn.microsoft.com/en-us/library/9y6s16x1(v=vs.71).aspx
  4. Mar 19, 2012 #3
    There are two things going on. First of all, scanf()'s return value is the number of items that it successfully pulled out of the input string. The format string is "%d", which means "look for an integer", so if you enter something that can be interpreted as an integer, it will put it into snum, and return 1. If you enter something that can't be interpreted as an integer, it returns 0. By extension, if the format string to scanf() was "%d %d", and you entered one number followed by a space and then another number, then scanf() would return 2.
    That's part 1. Part 2 is how the if statement works. Normally we think of an if statement as operating on a boolean value, but C doesn't actually have a boolean type. Instead, if() treats its argument as false any time it is 0, and true if it's any other value. The ! causes it to invert that, so the net result is that if the string contains a number, scanf() returns 1, so the if(!valid_input) does not fire. If the string doesn't contain a number, valid_input is 0, so the if statement is triggered, and the program exits with an error.
  5. Mar 19, 2012 #4
    rcgldr
    scanf() returns the number of fields successfully converted and assigned. It's not an error value. In this case, valid_input = scanf("%d", &snum); scanf returns 1 if a field was converted and assigned to snum, otherwise it returns a 0.
    There's no general consistency in the return values from the c or c++ library functions. If the return value from a typical function is not normally used, then the function may return an error value. If the function normally returns a pointer, then returing a pointer of NULL would usually indicate an error, and with windows, you'd have GetLastError(), _get_errno(), or _get_doserrno() to get the error value, depending on the function you called.
  6. Mar 19, 2012 #5
    Thanks everyone. I did learn at some point that scanf returns a value but must have forgotten. Makes sense now.
  7. Mar 20, 2012 #6
    It's been 3 years since I did any C programming, wish I kept it up. I can still understand most code, although, is valid_input a library defined function? If so, which library?
  8. Mar 20, 2012 #7
    D H
    Staff Emeritus
    valid_input is not a function. It is a variable, presumably of type int, in which the return value from scanf() is stored. The function scanf() is a part of the C standard library and returns the number of items that were assigned a value. In this case, there is only one item to be assigned, the number of students, so the function returns 1 indicating a value was parsed, 0 if there was something wrong in the input stream.
    I'm not thrilled with the if(!valid_input) scheme. My personal preference is to use ! for booleans only. The return value appears to be boolean in this case, but in general it isn't. I would instead use if (valid_input != 1) to test for input errors. That's just my personal preference, though.
  9. Mar 20, 2012 #8
    Yeah, valid_input was an integer variable. And I think the ! in front of the int is what confused me. I had done it another way but this was how the prof did it in his solution. I was just trying to understand why his way worked also.
  10. Mar 20, 2012 #9
    I always go back and forth on the issue of whether or not to use ! with non-boolean types. I generally don't use it for ints like this (precisely because it causes this confusion), but I've found myself doing it fairly often for pointer values to check for NULL. I suppose that's a bit ugly as well, but I guess I justify it by saying that the distinction between a NULL pointer and a non-NULL pointer is clearer than the distinction between 0 and 1, since the former feel like different types of things, but the latter are both just ints.
    Python, on the other hand, goes nuts with this concept. Since the language is duck-typed, anything that looks sort of empty, like an empty string/list/set/dict, as well as anything that evaluates numerically to 0, is considered false. So you can do things like:
    Code (Text):
    string = ''
    if not string:
       # Will be executed
    list = ['asdf']
    if list:
       # Will be executed
    # ...etc.
    It makes for some really convenient code, but sometimes it takes a second to figure out exactly what is actually happening.
