Is there an error on problem 77 of the 1996 Physics GRE test?
In summary, "Error on 96 physics gre" is the score a test taker receives on the Physics GRE exam, indicating that they scored higher than 96% of all other test takers. The score is calculated by comparing the test taker's score to all others and is important for those applying to graduate school in physics. A good score is typically in the 90th percentile or higher and can be improved through studying and preparation. However, a perfect score may not always be achievable due to the percentile ranking being based on the performance of all test takers.
dsr39
On problem number 77 on the 1996 Physics GRE test that is now available for practice, I believe there are two answer choices that are completely equivalent.
The test is here:
http://www.stanford.edu/group/sps/files/GR9677.pdf
I think answer choice (d) reduces down to choice (b), and I don't see anything barring me from making the algebraic simplifications. Is it really possible that ETS made a mistake that hasn't been found/reported or am I missing something?
Thanks for the help
- Dave
Looks the same
it is important to always carefully analyze and review data and findings. In this case, it is possible that there may be an error on problem number 77 of the 1996 Physics GRE test. It is always important to thoroughly check and verify all data and calculations, and to report any discrepancies or potential errors to the appropriate authorities. This will ensure the accuracy and reliability of the test and its results. It is also possible that there may be a valid explanation for the equivalent answer choices, and further investigation is necessary to determine the accuracy of the test. Thank you for bringing this to our attention and for your commitment to maintaining the integrity of scientific testing.
1. What is "Error on 96 physics gre"?
"Error on 96 physics gre" refers to the score that a test taker received on the Physics GRE exam. This score is often referred to as the "96th percentile score" and indicates that the test taker scored higher than 96% of all other test takers who took the exam.
2. How is the "Error on 96 physics gre" calculated?
The "Error on 96 physics gre" is calculated by comparing the test taker's score to the scores of all other test takers who took the exam. If the test taker's score is higher than 96% of all other scores, then they will receive an "Error on 96 physics gre" score.
3. Is a high "Error on 96 physics gre" score important?
A high "Error on 96 physics gre" score is generally considered to be important for those who are applying to graduate school in physics or related fields. It demonstrates a strong understanding of physics concepts and can make a candidate stand out among other applicants.
4. What is considered a good "Error on 96 physics gre" score?
A good "Error on 96 physics gre" score is typically considered to be in the 90th percentile or higher. This indicates that the test taker scored higher than 90% of all other test takers and is a strong indicator of their knowledge and abilities in physics.
5. Can the "Error on 96 physics gre" score be improved?
Yes, the "Error on 96 physics gre" score can be improved by studying and preparing for the exam. Practice tests, review materials, and working with a tutor can all help to improve a test taker's score. It is important to note, however, that the percentile ranking is based on the performance of all test takers, so a perfect score may not always be achievable.
  • STEM Academic Advising
11K
  • STEM Career Guidance
