How Many Steps Visible on an Inactive Escalator?
  • Thread starter viren_t2005
In summary, the number of visible steps on an inactive escalator can vary depending on the specific model and design, but on average there are about 20-25 steps. This is determined by safety regulations and standards set by governing bodies. In most cases, the number of visible steps cannot be changed due to the escalator's design, but some models may have adjustable features. The visible steps are typically not the same as the total number of steps because there are hidden and additional steps. While the number of visible steps does not directly affect the escalator's performance, any issues with the visible steps can impact its functionality and safety.
viren_t2005
An escalator is descending at constant speed . A walks down and takes 50 steps to reach the bottom. B runs down and takes 90 steps in the same time as A takes 10 steps. How many steps are visible when the escalator is not operating?
You have posted 7 problems in a row without showing any attempt to do them yourself! The only way to learn mathematics is to do mathematics- yourself!
The number of steps visible on an inactive escalator can vary depending on the design and length of the escalator. However, in this scenario, we can calculate the number of visible steps by using the information provided.
First, we can determine the speed at which the escalator is descending by dividing the total number of steps taken by A (50) by the time it took (10 steps). This gives us a speed of 5 steps per unit time.
Next, we can calculate the time it took for B to take 90 steps by using the speed calculated above. This gives us a total time of 18 units.
Since A and B took the same amount of time to reach the bottom of the escalator, we can set up a proportion to determine the number of steps visible when the escalator is not operating.
A's time: B's time = A's steps: B's steps
10:18 = 50:x
x = 90
Therefore, when the escalator is not operating, there are 90 steps visible. This is because B took 90 steps in the same amount of time that A took 10 steps, indicating that the escalator moves 9 steps for every 1 step taken by a person.
1. How many steps are typically visible on an inactive escalator?
The number of steps visible on an inactive escalator can vary depending on the specific model and design. However, on average, there are about 20-25 visible steps on an inactive escalator.
2. Is there a specific reason why only a certain number of steps are visible on an inactive escalator?
Yes, the number of visible steps on an inactive escalator is determined by safety regulations and standards set by governing bodies. These regulations ensure that there is enough space for people to safely enter and exit the escalator, as well as providing enough clearance for maintenance and emergency procedures.
3. Can the number of visible steps on an inactive escalator be changed?
In most cases, the number of visible steps on an inactive escalator cannot be changed because it is determined by the escalator's design and construction. However, some models may have adjustable features that allow for a slightly different number of visible steps.
4. Are the visible steps on an inactive escalator the same as the total number of steps?
No, the visible steps on an inactive escalator are typically not the same as the total number of steps. This is because there are usually a few hidden steps at the top and bottom of the escalator, as well as additional steps that are not visible due to the escalator's design.
5. Can the number of visible steps on an inactive escalator affect its overall performance?
The number of visible steps on an inactive escalator does not directly affect its performance. However, if there are any issues with the visible steps, such as uneven or worn out steps, it can impact the overall functionality and safety of the escalator.
