Does Decreased Humidity Increase Triboelectric Charge Accumulation?
  • Thread starter Phrak
  • Tags
    Humidity
In summary, according to Henry Ott's book Electromagnetic Compatibility Engineering, charge accumulated on an object can leave the object through leakage or arcing. In order to avoid arcing, leakage is preferred and can be affected by humidity. The higher the humidity, the faster the charge will leak off the object. The decay time for charge to be reduced to 37% of its initial value is dependent on the dielectric constant, conductivity, and surface resistivity of the material. This suggests that the first suggestion regarding humidity and conduction is correct. In high humidity situations, there is a higher chance for transfer of electrons and creation of static charge.
Phrak
4,267
Why does triboelectric charge accumulation increase with a decrease in humidity?
Is the inhumid air less conductive and allow a greater charge difference, or do dissimilar materials when rubbed against each other or pulled apart develop a greater potential difference than when they are in a dryer atmosphere?
This is what Henry Ott has to say about static discharge (ch 15.3) in his book Electromagnetic Compatibility Engineering:
Charge accumulated on an object leaves the object by one of two ways, leakage or arcing. Because it is better to avoid arcing, leakage is the preferred way to discharge an object. Charge can leak off an object through the air, because of humidity. The higher humidity, the faster the charge will leak off the object.
He then goes on to define the decay time (τ) it takes for the charge to be reduced to 37% of its initial value
τ = ε/σ = ερ
where ε is the dielectric constant of the material, σ is the conductivity and ρ is the surface resistivity. So, at least your first suggestion regarding humidity and conduction seems to be correct.
ok, a more low key answer to your question. consider first what static IS and how it builds; the whole friction and transfer of electrons blah blah.
in high humidity situations, the air has a higher density of molecules and such bouncing off each other. the more interaction, the higher the chance to transfer electrons and create static charge.
1. What is ESD?
ESD stands for electrostatic discharge. It is a sudden flow of electricity between two objects with different electric potentials. It can occur when two objects come into contact or are separated, causing a rapid transfer of electrons.
2. How does humidity affect ESD?
Humidity affects ESD by altering the conductivity of the air. Higher humidity levels make the air more conductive, which allows for the faster dissipation of static charges. This helps to reduce the buildup of static electricity and minimize the occurrence of ESD events.
3. What are the common sources of ESD?
The most common sources of ESD are friction, triboelectric charging, and electrostatic induction. Friction occurs when two materials rub against each other, causing a transfer of electrons. Triboelectric charging happens when two materials are separated after being in contact, resulting in a charge imbalance. Electrostatic induction occurs when charged objects influence the charge distribution on nearby objects.
4. How can ESD and humidity be controlled in a laboratory or manufacturing setting?
To control ESD and humidity in a laboratory or manufacturing setting, several measures can be taken. These include using humidity control devices such as dehumidifiers or humidifiers, using anti-static flooring and furniture, grounding all equipment and personnel, and using proper ESD protective equipment such as wrist straps and grounding mats.
5. What are the potential consequences of ESD in a laboratory or manufacturing setting?
The consequences of ESD in a laboratory or manufacturing setting can range from minor disruptions to catastrophic failures. ESD can damage sensitive electronic components, leading to malfunctions or complete failure of equipment. It can also cause data loss and compromise the integrity of experiments or production processes. In extreme cases, ESD can even pose a safety hazard to personnel and cause fires or explosions.
  • Electrical Engineering
