fluidistic
- 261
Hi PF,
I'm getting an headache on this problem.
Rayleigh put a milligram of oil which density is [tex]0.9g/cm^3[/tex] on a water surface and found out that the oil covered an area of [tex]0.9 m^2[/tex].
1)What is the height of the oil film?
2)The height of the oil film is of the same order as a molecule of oil, which lead us to suppose that the oil film is one molecule thin.
Suppose that the three dimensions of the oil molecule are the same, find the molecular volume of oil.
3)If the molar mass of oil is [tex]282.5g/mol[/tex], estimate Avogadro's number through the comparison of molecular volume and molar volume.
1)Density [tex]\rho[/tex] is worth [tex]\frac{m}{V}=0.9[/tex] so [tex]V=\frac{0.001}{0.9}=0.00111111...cm^3[/tex] where [tex]V[/tex] is the volume of the oil drop.
Now [tex]V=base \cdot h[/tex] hence [tex]h=0.00001234567889cm[/tex].
2)Calculating the volume of a molecule lead me nowhere. Instead in order to find Avogadro's number I think it's more effective to follow this : as the dimensions of the molecule are the same and that the diameter or height or length of it is worth [tex]0.00001234567889cm[/tex], each molecule cover a surface of [tex](0.00001234567889cm)^2[/tex]. Now I can find how many molecules are in the drop. Because it has a surface of [tex]0.9m^2[/tex] or [tex]90cm^2[/tex]. [tex]\frac{90}{(0.00001234567889cm)^2}=5.904900127\times 10^{11}[/tex].
Now for part 3), we know that the oil drop was [tex]0.001g[/tex] and that a mole of oil is [tex]282.5g[/tex]. So that I must multiply by [tex]282500[/tex] the number of molecules in the drop to find the number of molecule in a mole, that is Avogadro's number. But doing so I find [tex]1.661320857 \times 10^{17}[/tex]...
P.S.: I also tried via the way they suggested, but found something like [tex]3.5\times 10 ^{17}[/tex] and I had to suppose that the form of the molecules was spherical.
Of course I made errors and I'm missing something. If you could help me that would be kind! Thank you.
Avogadro's number is about [tex]6.02 \times 10^{23}[/tex].The Attempt at a Solution
