Etch-a-Sketch Tech Support
  • MHB
  • Thread starter soroban
  • Tags
    Support
In summary, to turn off your Etch-a-Sketch, get rid of funny lines, undo, create a new document, set background and foreground colors, reboot, delete a document, and save a document, simply pick it up and shake it. To save a document permanently, gently place it on a flat surface and turn the knobs to "Off," or take a photo of your drawing.
soroban
194
. . Etch-a-Sketch Technical SupportHow do I turn off my Etch-a-Sketch?
Pick it up and shake it.
How do I get rid of those funny little lines?
What is the shortcut for Undo?
How do I create a new document?
How do I set the background and
,. . foreground to the same color?
How do I reboot my Etch-a-Sketch?
How do I delete a document on my Etch-a-Sketch?
How do I save my Etch-a-Sketch document?
Don't shake it.
Place it gently on a flat surface and turn the knobs to the "Off" position. Your drawing will be saved until you shake the Etch-a-Sketch again. Alternatively, you can take a photo of your drawing with a camera or phone to save it digitally.
1. How do I fix a stuck knob on my Etch-a-Sketch?
To fix a stuck knob on your Etch-a-Sketch, try gently tapping on the sides of the screen to loosen any stuck particles. If that doesn't work, open the back of the toy and gently shake it to dislodge any debris. If the issue persists, you may need to replace the knobs.
2. What should I do if my Etch-a-Sketch won't erase?
If your Etch-a-Sketch won't erase, make sure the knobs are turned to the "off" position and try shaking the toy vigorously. If that doesn't work, check to see if the screen is dirty and clean it with a soft, dry cloth. If the issue persists, you may need to replace the toy.
3. Can I save my Etch-a-Sketch drawings?
No, unfortunately the Etch-a-Sketch does not have a save feature. Once you shake the toy to erase the screen, the drawing is gone forever. However, you can take a picture of your drawing with a camera or phone to save it digitally.
4. How do I create straight lines on my Etch-a-Sketch?
To create straight lines on your Etch-a-Sketch, hold down one knob while turning the other knob. This will prevent the line from being drawn at an angle. You can also use a ruler or straight edge to guide your lines.
5. Is it possible to replace the screen on my Etch-a-Sketch?
Yes, it is possible to replace the screen on your Etch-a-Sketch. However, it requires some technical skill and special tools. We recommend contacting a professional or purchasing a new toy if your screen is damaged or broken.
  • General Discussion
  • STEM Academic Advising
