Euclidean Geometry Question
In summary, a smooth parametrically defined volume V can be represented by the equation r(u,s,v) = x(u,v,s)i + y(u,v,s)j +z(u,v,s)k + w(u,v,s)l, where (u,s,v) are elements of E. The volume can be calculated by taking the triple integral over E of |ru||rv||rs||sin(phi)*sin(theta)|dV, where sin(phi) and sin(theta) are determined by the angles between ru and rv, and ru and rs, respectively. However, this calculation may not be accurate due to the fact that ||sin(phi)*sin(theta)| is not a constant.
Edwin
162
Suppose you have a smooth parametrically defined volume V givin by the following equation.
f(x,y,z,w)= r(u,s,v) = x(u,v,s)i + y(u,v,s)j +z(u,v,s)k + w(u,v,s)l
Consider the vectors ru=dr/du, where dr/du is the partial derivitive of r with respect to the parameter u. Similarly, rv = dr/dv, rs=dr/ds are the partial derivitives of r with respect to the parameters v and s, respectively.
I presume that ru(u0,v0,s0), rv(u0, v0, s0), and rs(u0,v0,s0) form a three dimensional parallelpiped that represents the rate of change of the three dimensional surface volume in four dimensional Euclidean space.
The angle theta between ru and rv is arccosine((ru*rv)/(|ru||rv|))
Similarly, the angle phi between ru and rs is arccosine((ru*rs)/(|ru||rs|).
The height h1 of the parallelogram p1 formed by ru and rv is the magnitude of the projection of rv onto the perpindicular of p1 and is equal to
|rv|sin(theta). The area A1 of this parallelogram is
|ru|*h1 = |ru||rv|sin(theta).
The height h2 of the parallelogram p2 formed by ru and rs is the magnitude of the projection of rs onto the perpindicular of p2, and is equal to |rs|sin(phi)
The area of A2 of this parallelogram is |ru|*h2 = |ru||rs|sin(phi).
The volume of the parallelpiped V = the area of either of the parallelograms times the height of the other parallelgram.
A2*(h1) = A1*(h2) =|ru||rv||rs||sin(phi)*sin(theta)|
Based on this, I conjecture the following:
If a smooth parametrically defined volume V is givin by the following equation:
Where (u,s,v) are elements of E, and
V is covered just once as (u,v,s) varies throughout the parameter domain E, then the "Surface Volume" is
the tripple integral over E of =|ru||rv||rs||sin(phi)*sin(theta)|dV
Where ||sin(phi)*sin(theta)|is a constant.
Does this sound accurate?
Inquisitively,
Edwin
Oops! ||sin(phi)*sin(theta)|is not a constant!
it's |arccosine((ru*rv)/(|ru||rv|))*arccosine((ru*rs)/(|ru||rs|)|.
Yes, your conjecture seems accurate. The triple integral over E of |ru||rv||rs||sin(phi)*sin(theta)|dV represents the volume of the parallelpiped formed by the three vectors ru, rv, and rs, which in turn represents the rate of change of the three-dimensional surface volume in four-dimensional Euclidean space. This integral takes into account the angles between the vectors and their magnitudes, as well as the constant ||sin(phi)*sin(theta)|. So, if V is covered just once as (u,v,s) varies throughout the parameter domain E, then this integral accurately represents the surface volume of V. Great job on your analysis and explanation!
1. What is Euclidean geometry?
Euclidean geometry is a type of geometry that is based on a set of axioms, or basic principles, developed by the mathematician Euclid in ancient Greece. It is also known as flat or classical geometry, and it is the most commonly used type of geometry in everyday life.
2. What are the basic principles of Euclidean geometry?
The basic principles, or axioms, of Euclidean geometry include the concepts of points, lines, and planes, as well as postulates such as the Pythagorean theorem and the parallel postulate.
3. How is Euclidean geometry different from other types of geometry?
Euclidean geometry differs from other types of geometry, such as non-Euclidean geometry, in that it follows the parallel postulate, which states that given a line and a point not on that line, there is only one line parallel to the given line that passes through the point. In non-Euclidean geometry, this postulate may not hold true.
4. What are some real-world applications of Euclidean geometry?
Euclidean geometry has many applications in daily life, including architecture, engineering, and navigation. It is also used in fields such as computer graphics and game development.
5. Can Euclidean geometry be proven?
Euclidean geometry is a deductive system, meaning that it is based on a set of axioms and follows logical reasoning to prove theorems. While it cannot be proven in the same way as mathematical theorems, it is generally accepted as a consistent and reliable system for understanding and describing the physical world.
  • Differential Geometry
  • Calculus
