How is Euclideanization of Path Integrals Justified in Quantum Field Theory?
In summary, the process of Euclideanizing path integrals involves using complex analysis and the Wick Rotation to transform the fields and correlation functions into a different set of axioms, known as the Osterwalder-Schrader axioms. This allows for the existence of a probability theory, known as the path integral, which is the Fourier transform of a functional obeying Frohlich's axioms. This process is justified by the reasonable assumptions and analytic continuation of the correlation functions.
TriTertButoxy
194
I can't find any good references on Euclideanizing path integrals (from Minkowski to Euclidean metric).
I understand how this is done in perturbative 1-loop calculations, where the pole structure of the Feynman propagators are used to perform the so-called Wick Rotation. This seems to be a perfectly valid procedure in light of complex analysis (in particular, Cauchy's theorem).
However, in path integrals, there are no poles per-se. How is the passage into imaginary time justified? AND does such Euclideanization always yield a Hamiltonian in the exponent?
This is a complex topic.
Basically you can show that a field theory whose fields obey a reasonable set of axioms (Wightman-Garding axioms) give a set of correlation distrbutions obeying a separate reasonable set of axioms (Wightman axioms).
These axioms imply the correlation functions have an analytic continuation called Schwinger functions and that these functions obey another set of axioms, the Osterwalder-Schrader axioms. A slight additional assumption on the analytic behaviour of the Schwinger functions (provably satisfied in all realistic field theories) then shows they are derivatives of a functional obeying another set of axioms (Frohlich's axioms). Via Minlos theorem this then implies the existence of a probability theory of which this Functional is the Fourier transform. This probability theory is the path integral.
1. What is a Euclideanizing path integral?
A Euclideanizing path integral is a mathematical technique used in quantum field theory to simplify calculations by converting the time variable from real time to imaginary time. This allows for easier mathematical manipulation and interpretation of physical phenomena.
2. Why is Euclideanizing path integrals useful?
Euclideanizing path integrals are useful because they allow for easier mathematical manipulation and interpretation of physical phenomena in quantum field theory. They also help to solve problems that would be difficult to solve in real time.
3. How is a Euclideanizing path integral performed?
A Euclideanizing path integral is performed by converting the time variable from real time to imaginary time and then performing the integral over all possible paths in a given system. This is done using a mathematical technique known as Wick rotation.
4. What are the benefits of using Euclideanizing path integrals?
One of the main benefits of using Euclideanizing path integrals is that they simplify calculations in quantum field theory and allow for easier interpretation of physical phenomena. They also help to solve problems that would be difficult to solve in real time. Additionally, they can provide insight into the behavior of quantum systems and allow for the prediction of new physical phenomena.
5. Are there any limitations to using Euclideanizing path integrals?
While Euclideanizing path integrals have many benefits, they also have some limitations. They may not be applicable to all systems in quantum field theory and may produce incorrect results in certain cases. Additionally, they can be challenging to perform and interpret, requiring advanced mathematical knowledge and skills.
  • Quantum Physics
