Solve Eudiometry Problem: NH3 & H2 Mixture, 40 ml Oxygen Added
  • Thread starter konichiwa2x
In summary, the problem involves the decomposition of a mixture of NH3 and H2 into nitrogen and hydrogen. Oxygen is then added and the mixture is sparked again, resulting in the formation of H2O. After cooling and shaking with alkaline pyrogallol, a contraction of 6ml was observed, indicating that 6ml of the gas is O2. From this information, the percentage of NH3 in the original mixture can be calculated.
konichiwa2x
81
Hi, can someone please explain how to do this problem? I don't even understand the question properly.
50 ml of a mixture of NH3 and H2 was completely decomposed by sparking into nitrogen and hydrogen. 40 ml of Oxygen was then added and the mixture was sparked again. After cooling to room temperature, the mixture was shaken with alkaline pyrogallol and a contraction of 6ml was observed. Calculate the percentage of NH3 in the original mixture. (Assume that nitrogen does not react with Oxygen)
thanks.
50 ml of a mixture of NH3 and H2 was completely decomposed by sparking into nitrogen and hydrogen.--> This means that NH3 will decompose into N2 and H2. And H2 will remain as H2.
40 ml of Oxygen was then added and the mixture was sparked again.--> O2 added will react with H2 to form H2O. Since given in question is that N2 does not react with O2.
After cooling to room temperature, the mixture was shaken with alkaline pyrogallol and a contraction of 6ml was observed.--> Alkaline pyrogallol will absorb O2. This means that 6ml of the gas is O2.
Then, you can use the information 6ml of O2 to work backward to calculate the percentage of NH3 in the original mixture.
thanks fopr explaining that!
1. What is eudiometry and why is it important?
Eudiometry is a branch of chemistry that deals with the measurement and analysis of gases. It is important because it allows scientists to determine the composition and properties of gas mixtures, which is crucial in many industrial and scientific processes.
2. How do you solve a eudiometry problem involving NH3 and H2?
To solve a eudiometry problem involving NH3 and H2, you first need to balance the chemical equation for the reaction between the two gases. Then, using the given information, you can calculate the moles of each gas present in the mixture. Finally, using the ideal gas law and stoichiometry, you can determine the volume of oxygen needed to completely react with the NH3 and H2.
3. What is the purpose of adding 40 ml of oxygen to the NH3 and H2 mixture?
The purpose of adding 40 ml of oxygen is to ensure that there is enough oxygen present to react with all of the NH3 and H2 in the mixture. This allows for a complete reaction and accurate measurement of the gases.
4. What factors can affect the accuracy of eudiometry calculations?
There are several factors that can affect the accuracy of eudiometry calculations, including experimental errors, impurities in the gases, and incomplete reactions. It is important to carefully measure and control these factors to ensure accurate results.
5. How can eudiometry be used in real-world applications?
Eudiometry has many real-world applications, such as in industrial processes to monitor and control gas mixtures, in environmental science to analyze air and water quality, and in research labs to study the properties of gases. It is also used in the production and testing of various products, such as fuels and pharmaceuticals.
  • Mechanical Engineering
11K
10K
