Eukaryotic Ribosome Question
  • Thread starter whamola411
In summary, a eukaryotic ribosome contains 4 different rRNA molecules and about 82 different proteins. The genome contains more copies of each rRNA gene compared to ribosomal protein genes due to the need for a higher number of rRNA molecules to keep up with the protein:rRNA ratio and to form multiple ribosomes. While transcription of a ribosomal protein gene results in multiple copies of the protein, transcription of an rRNA gene only results in one copy of the rRNA molecule. Therefore, multiple copies of rRNA genes are necessary to produce a sufficient amount of rRNA for ribosome formation.
whamola411
A eukaryotic ribosome has 4 different rRNA molecules and about 82 different proteins. There is a single copy of the gene for each of the proteins; however there are multiple copies of each rRNA gene. Why does the genome contain more copies of each rRNA gene than for each ribosomal protein gene?
My thinking is that there needs to be so many rRNA gene copies to keep up with the extremely offset ratio of protein:rRNA. I feel like there has to be a better answer though. Thanks!
If you create one molecule of mRNA for one of the ribosomal proteins, how many ribosomal proteins would you produce. One? More than one? Less than one?
I'm really not sure. I would think none because the ribosomes, and thus their rRNA are recycled after translation.
In general, a single mRNA molecule will get read by multiple ribosomes creating multiple proteins.
I understand that, but each of those ribosomes is made up of rRNA and proteins. So why would you need more copies of the rRNA than protein?
How many rRNA molecules will you get if you have RNA polymerase transcribe one rRNA gene?
One.
So since transcription of the gene for a ribosomal protein results in multiple copies of the protein molecule while transcription of the gene for an rRNA results in only one copy of the rRNA molecule, do you now see why you need multiple copies of the rRNA genes?
Is it because in order to form many ribosomes, there will need to be a high number of rRNA, in addition to the high number of proteins produced?
What is a eukaryotic ribosome?
A eukaryotic ribosome is a cellular structure responsible for protein synthesis. It is found in the cytoplasm of eukaryotic cells and is made up of two subunits, the large and small subunit, which come together during protein synthesis.
What is the structure of a eukaryotic ribosome?
A eukaryotic ribosome is composed of two subunits, the large and small subunit, which are made up of proteins and ribosomal RNA (rRNA). The large subunit is responsible for the catalytic activity of protein synthesis, while the small subunit helps to position the messenger RNA (mRNA) during translation.
How is a eukaryotic ribosome different from a prokaryotic ribosome?
One of the main differences between eukaryotic and prokaryotic ribosomes is their size. Eukaryotic ribosomes are larger and more complex, with a size of 80S (where S stands for Svedberg units), while prokaryotic ribosomes are smaller with a size of 70S. Additionally, eukaryotic ribosomes have more proteins and rRNA than prokaryotic ribosomes.
What is the function of a eukaryotic ribosome?
The main function of a eukaryotic ribosome is to synthesize proteins by decoding the genetic information carried by messenger RNA (mRNA). This process, known as translation, involves the ribosome reading the sequence of nucleotides on the mRNA and assembling amino acids into a polypeptide chain according to the genetic code.
How does a eukaryotic ribosome interact with other cellular components?
Eukaryotic ribosomes interact with other cellular components in various ways. They receive mRNA from the nucleus and interact with transfer RNA (tRNA) to bring in the appropriate amino acids for protein synthesis. They also interact with other proteins and enzymes involved in translation, as well as cellular structures such as the endoplasmic reticulum for protein transport and modification.
  • Biology and Medical
