• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Euler Constant
  • Thread starter the_kid
I need to verify an integral representation of the Euler constant:
[itex]\int^{1}_{0}[/itex][itex]\frac{1-e^{-t}}{t}[/itex]dt-[itex]\int^{\infty}_{1}[/itex][[itex]\frac{e^{-t}}{t}[/itex]dt=[itex]\gamma[/itex]
2. Relevant equations
3. The attempt at a solution
OK, I'm supposed to use this fact (which I have already proved):
[itex]\sum^{N}_{n=1}[/itex][itex]\frac{1}{n}[/itex]=[itex]\int^{1}_{0}[/itex][itex]\frac{1-(1-t)^{n}}{t}[/itex]dt.
Then I am supposed to rescale t so that I can apply the follow definition of the exponential function:
lim as n-->infinity of (1+[itex]\frac{z}{n}[/itex])[itex]^{n}[/itex]=[itex]\sum^{\infty}_{k=0}[/itex][itex]\frac{z^{k}}{k!}[/itex]=e[itex]^{z}[/itex]
I'm not seeing how I can use the first fact at all...
116
Someone has to have an idea on this one...
jbunniii
Insights Author
179
I assume that should be a capital N in your integral expression for [itex]\sum_{n=1}^{N} \frac{1}{n}[/itex]:
[tex]\sum_{n=1}^{N} \frac{1}{n} = \int_{0}^{1} \frac{1 - (1-t)^N}{t}dt[/tex]
Assuming that is the case, you could let [itex]u = Nt[/itex]; then your integral becomes
[tex]\sum_{n=1}^{N}\frac{1}{n} = \int_{0}^{N} \frac{1 - \left(1 - \frac{u}{N}\right)^N}{u} du[/tex]
and you could break this apart as [itex]\int_{0}^{1} + \int_{1}^{N}[/itex]. Dunno if this will get you anywhere but it seems promising.
116
Hmm... OK, this makes sense. What do you mean with the last part about splitting the integral up?
jbunniii
Insights Author
179
Well, I suggested that because one of the integrals you'll eventually need has 0 and 1 as its endpoints:
[tex]\int_{0}^{1}\frac{1 - e^{-t}}{t} dt[/tex]
So if you can justify interchanging the order of limit and integration,
[tex]\lim_{N \rightarrow \infty} \int_{0}^{1}\frac{1 - \left(1 - \frac{u}{N}\right)^N}{u}du[/tex]
will give you what you need.
That leaves you with the part from 1 to N:
[tex]\int_{1}^{N}\frac{1 - \left(1 - \frac{u}{N}\right)^N}{u}du[/tex]
which you could further split up as
[tex]\int_{1}^{N}\frac{1}{u}du - \int_{1}^{N}\frac{\left(1 - \frac{u}{N}\right)^N}{u}du[/tex]
Obviously the term on the left will be useful, given the definition of [itex]\gamma[/itex]. And the term on the right looks like it might converge as [itex]N \rightarrow \infty[/itex] to one of the other integrals you need, although that will also need to be proved.
116
OK, I've been able to work this out successfully. I'm stuck with two small things:
(1) How can I justify switching the order of integration and summation, as you mentioned?
(2) How do I show that the last integral converges?
116
Never mind, I was able to get the integral to converge. Now my only questions is what justifies switching the order? I know this is a subtle point, but I'd like to understand it.
jbunniii
Insights Author
179
A sufficient condition for switching the order is if the convergence is uniform, i.e., if
[tex]\lim_{N \rightarrow \infty} \frac{1 - \left(1 - \frac{u}{N}\right)^N}{u}[/tex]
converges uniformly in [itex][0,1][/itex]. This in turn will be true if and only if
[tex]\lim_{N \rightarrow \infty} \left(1 - \frac{u}{N}\right)^N[/tex]
116
Hmm, ok, great. That makes sense. How can I show that this is true? Weirestrass M-test?
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
