Evaluate integration
  • Thread starter CellCoree
CellCoree
42
Evaluate [tex]\int t^{14} ln(t) dt[/tex]
using integration by parts and formula [tex]uv-\intv du[/tex]
u=ln(t)
du=1/t
dv=t^14
v=t^15/15
lnt*t^15/15-[tex]\int[/tex]t^15/15*1/t
lnt*t^15/15-t^14*log(t)
i don't know what I am doing wrong, please help
Answers and Replies
jamesrc
First step is fine. You're over-thinking the second step:
[tex] \int{\frac{t^{15}}{15} \frac{dt}{t}} = \int{\frac{t^{14}}{15}dt = \frac{t^{15}}{225} [/tex]
So the answer should read:
[tex] \int{\left(\ln t\right) t^{14} dt} = \frac{t^{15}}{15} \left(\ln t - \frac{1}{15} \right) [/tex]
arildno
Dearly Missed
10,089
135
u=ln(t)
du=1/t
dv=t^14
v=t^15/15
DO NOT USE THIS HORRIBLE MIXTURE OF INTEGRATION BY PARTS AND INTEGRATION BY SUBSTITUTION!
Write:
[tex]\int{uv'}dt=uv-\int{u'v}dt[/tex]
[tex]u=ln(t)\to{u}'=\frac{1}{t}[/tex]
[tex]v'=t^{14}\to{v}=\frac{1}{15}t^{15}[/tex]
CellCoree
42
Write:
what do you mean? your setup is just like mines
arildno
Dearly Missed
10,089
135
Nope!
1. "Using formula uv-du"
Complete nonsense
If you want to use this method properly, write:
udv=d(uv)-vdu
2.Furthermore
you use a meaningless constuction like du=1/t
If you want to use this method, you must write du=1/t*dt
3. Your integral lacks dt, and is therefore meaningless as well
CellCoree
42
ok i know how you got [tex] \int{\frac{t^{15}}{15} \frac{dt}{t}} = \int{\frac{t^{14}}{15}dt [/tex]
but how did you get
[tex]\int{\frac{t^{14}}{15}dt = \frac{t^{15}}{225} [/tex]
i know you got the anti-derv. of it, and i tried to look in my book for a form like that, but i can't find it. can you explain to me how you did that?
for [tex]\int{\frac{t^{14}}{15}dt[/tex] i used u-du sub.
u=14
du=u+1
so... t^u/du but i can't seem to find that form in the book
Dr Transport
Insights Author
761
[tex] \int \frac{t^{14}}{15} dt = \frac{1}{15}\int t^{14} dt = \frac{1}{15}\frac{t^{15}}{15} =
\frac{t^{15}}{(15)^{2}} = \frac{t^{15}}{225} [/tex]
Suggested for: Evaluate integration
  • Last Post
