Evaluating an infinite series
  • Thread starter Ali812
Ali812
[tex]
\sum_{n=1}^{\infty}\frac{sinn}{2^n}
[/tex]
Definition of a geometric series:
[tex]
\sum_{n=0}^{\infty}x^n=\frac{1}{1-x}
[/tex]
Basically I can use the geometric series idea and implement it into the denominator of the question (i.e. sub x=2 into the equation from part b and change the lower index to n=1)
[tex]
\sum_{n=1}^{\infty}2^n=\frac{1}{1-2}
[/tex]
Taking the derivate of both sides:
[tex]
\sum_{n=1}^{\infty}n2^{n-1}=\frac{1}{(1-2)^2}
[/tex]
Multiplying both sides by 2:
[tex]
\sum_{n=1}^{\infty}n2^n=\frac{2}{(1-2)^2}
[/tex]
Of course I can simplify the question furthermore and get a single value as a result, my problem is I don't understand on how to incorporate the numerator (sin n) into the problem. Is my approach correct, or am I substituting the wrong x-value?
Thanks in advance for any help/advice. :)
Answers and Replies
8,280
What exactly are you supposed to do with this series?
Ali812
Suppose to solve for the overall sum I'm assuming, the question simply states "Find [tex]
[/tex]."
Mathnerdmo
41
There are two problems here:
(1) The equation you gave for the geometric series only works for |x| < 1.
(2) We can't simply change the lower index to n=1.
Ali812
(1) The equation for the geometric series only works for |x| < 1.
Well that was the only approach I could think of, any other method to solve this question? A starting tip/hint will suffice.
Mathnerdmo
41
I'm also having some difficulty with the sine in the numerator - I haven't done something like this in a while.
What class is this for, by the way? (to give me an idea of methods you have)
Also, if there is a solution with geometric series, the problems I pointed out can be fixed... you just need to be careful about what you use.
Ali812
Calculus II (First year)
Ali812
From what I can tell, you can change the lower index to n=1, but I assume I will have to check for convergence first, if the series does converge, I can move ahead with this method, if not, I will need an alternative.
Ali812
If you know Euler's formula (see http://en.wikipedia.org/wiki/Euler's_formula ), then you should try using that.
I believe we haven't learned that yet unfortunately, however I have determined that the series is absolutely convergent via the comparison test. What r value can i use so [tex]
|r| < 1
[/tex], involved with the numerator as well? :S
Mathnerdmo
41
Hrmmm... I don't know a solution if you can't use Euler's formula. Sorry.
(doesn't mean there isn't one, but I'm not seeing it)
Dick
26,263
619
I'm with Mathnerdmo. It's pretty easy if you put r=exp(i)/2 and realize your sum is related to the imaginary part of sum(r^n). So |r|<1 and you can treat it as a geometric series. Are you sure you didn't do that in Calc I and just forgot it?
Ali812
After skimming through some info on Euler's formula, I can substitute sinn= (e^in - e^(-in)) / 2i, I'm confused as to what you are trying to state, could you perhaps elaborate? How exactly did you derive with r = exp(i)/2?
Dick
26,263
619
exp(i)^n=exp(in)=cos(n)+i*sin(n). If you sum that series and take the imaginary part you get the sum of sin(n). What happens if you do the same thing with (exp(i)/2)^n?
Suggested for: Evaluating an infinite series
  • Last Post
  • Last Post
  • Last Post
  • Last Post
9K
  • Last Post
  • Last Post
  • Last Post
