Homework Help: Evaluating definite integral
  1. Mar 24, 2013 #1
    [tex]\int_{0}^{2\pi} \frac{dx}{1+e^{\sin x}}[/tex]
    2. Relevant equations
    3. The attempt at a solution
    Let ##I=\int_{0}^{2\pi} \frac{dx}{1+e^{\sin x}}##
    Since ##\int_{a}^{b}f(x) dx=\int_{a}^{b} f(a+b-x)dx##
    Hence,
    [tex]I=\int_{0}^{2\pi} \frac{dx}{1+e^{-\sin x}}=\int_{0}^{2\pi} \frac{e^{\sin x}dx}{1+e^{\sin x}}[/tex]
    [tex]2I=\int_{0}^{2 \pi}dx[/tex]
    [tex]I=\pi[/tex]
    This is the right answer but when I try it with the following method it turns out to be zero.
    Let ##\sin x=t## or ##\cos xdx=dt##. Multiply the numerator and denominator by ##\cos x## & ##\cos x=\sqrt{1-t^2}##
    The integral transforms to
    [tex]I=\int_{0}^{0} \frac{dt}{\sqrt{1-t^2} (1+e^t)}[/tex]
    Both the upper and lower limits are zero. The value of I should be zero. What have I done wrong? :confused:
    Any help is appreciated. Thanks!
  3. Mar 24, 2013 #2
    Yo Naruto fan :)
    Last year i was confused with the same problem... when a trigonometric function is applied to 0 or 2∏, we get the same result... As trigonometric functions are periodic. You can draw a graph and u can see that the area under the curve is not 0. This implies that you can not substitute a trigonometric function like "sin x" with a variable like "t" when the difference between the upper and lower limits is greater than ∏/2... It doesn't appear wrong... but it is something like to prove LHS=RHS by multiplying both sides of an equation with zero...!
    Hope this helped!
  4. Mar 24, 2013 #3
    Hello there,
    Be careful with:
    [itex]\cos x = \sqrt{1- \sin^{2} x}[/itex]​
    In particular, for [itex]0 \le x \le 2\,\pi[/itex]:
    [itex]
    \cos x = \left \{ \begin{array}{ll}
    \sqrt{1- \sin^{2} x} & 0 \le x \le \pi/2\\
    -\sqrt{1- \sin^{2} x} & \pi/2 < x \le 3\,\pi/2 \\
    \sqrt{1- \sin^{2} x} & 3\,\pi/2 < x \le 2\,\pi
    \end{array}\right . [/itex]​
    In your case, split the integral in 3 cases, and go ahead.
  5. Mar 24, 2013 #4
    Curious3141
    JFGobin has provided the correct explanation, but you should note that once you split the integral up, you don't really save any work - you basically need to do the same thing you did the first time to get the result (plus at one point you need to evaluate ##\displaystyle \int_{-1}^{1}\frac{1}{\sqrt{1-t^2}}dt##, which is easy, but still extra work). You do get the same answer though (I checked).
  6. Mar 24, 2013 #5
    Thank you Curious and jfgobin! :smile:
    I tried your advice but still cannot reach the final answer.
    The given integral can be separated into three integrals.
    [tex]I=\int_{0}^{\pi/2} \frac{\cos x}{\sqrt{1-\sin^2x}(1+e^{\sin x})}dx-\int_{\pi/2}^{3\pi/2} \frac{\cos x}{\sqrt{1-\sin^2x}(1+e^{\sin x})}dx+\int_{3\pi/2}^{2\pi} \frac{\cos x}{\sqrt{1-\sin^2x}(1+e^{\sin x})}dx[/tex]
    Using the substitution ##\sin x=t##.
    [tex]I=\int_{0}^{1} \frac{dt}{\sqrt{1-t^2}(1+e^t)}+\int_{-1}^{1} \frac{dt}{\sqrt{1-t^2}(1+e^t)}+\int_{-1}^{0} \frac{dt}{\sqrt{1-t^2}(1+e^t)}[/tex]
    [tex]I=I_1+I_2+I_3[/tex]
    I did a change of variable in ##I_3##, I substituted ##t=-x## or ##dt=-dx##. The integral ##I_3## transforms to
    [tex]I_3=\int_{1}^{0} \frac{-dx}{\sqrt{1-x^2}(1+e^{-x})}[/tex]
    which is equivalent to
    [tex]I_3=\int_{0}^{1} \frac{e^tdt}{\sqrt{1-t^2}(1+e^{t})}[/tex]
    Now I can add ##I_3## and ##I_1##. I end up with this:
    [tex]I=\int_{0}^{1} \frac{dt}{\sqrt{1-t^2}}+\int_{-1}^{1} \frac{dt}{\sqrt{1-t^2}(1+e^t)}[/tex]
    But my expression doesn't include the integral mentioned by Curious3141. :confused:
  7. Mar 24, 2013 #6
    Dick
    ##I_1+I_3=I_2##. So if ##I_1+I_3=\int_{0}^{1} \frac{dt}{\sqrt{1-t^2}}## then ##I=2\int_{0}^{1} \frac{dt}{\sqrt{1-t^2}}=\int_{-1}^{1} \frac{dt}{\sqrt{1-t^2}}## (because the integral is symmetric in t).
  8. Mar 24, 2013 #7
    How do you get a factor of 2? :confused:
    [tex]I_1=\int_0^1 \frac{dt}{\sqrt{1-t^2}(1+e^t)}[/tex]
    [tex]I_3=\int_0^1 \frac{e^t dt}{\sqrt{1-t^2}(1+e^t)}[/tex]
    [tex]I_1+I_3=\int_0^1 \frac{dt}{\sqrt{1-t^2}}[/tex]
    How do you get ##I_1+I_3=I_2##?
  9. Mar 24, 2013 #8
    Dick
    Look back at the expressions you started with for I1, I2 and I3. I3 integrates ##\frac{dt}{\sqrt{1-t^2}(1+e^t)}## from -1 to 0, I1 integrates from 0 to 1. Put them together and it's the same as integrating -1 to 1. Which is I2.
  10. Mar 24, 2013 #9
    Silly me. :redface:
    Thanks a lot, Dick! :smile:
Have something to add?
Draft saved Draft deleted
Loading...
