Evaluating electric field
In summary, when you are asked to evaluate an expression for some variable >> some other variable, you use the Taylor series expansion to approximate the expression.
[SOLVED] Evaluating electric field
I have an electric field in the z-direction given by: (where sigma is charge per area and z is a distance)
[tex]
{\bf{E}} = \frac{{\sigma z}}{{2\pi \varepsilon _0 }}\left( {\frac{1}{z} - \frac{1}{{\sqrt {R^2 + z^2 } }}} \right){\bf{z}}
[/tex]
I have to evaluate this for z >> R.
Do I just insert R=0 or what? I overheard someone talk about Taylor-expanding it, but I don't see how/why?
Take a factor [itex]z^2[/itex] out of the [itex]R^2 + z^2[/itex] term.
Thanks, but why?
What is the method when I am asked to evalute an expression for some variable >> some other variable?
Niles said:
Thanks, but why?
After you do it, I'll give the motivation for the step.
I get 1/R instead of 1/sqrt(R^2+z^2).
I was looking for
[tex]R^2 + z^2 = z^2 \left( \frac{R^2}{z^2} + 1 \right).[/tex]
What can you say about the first term inside the brackets?
It goes to 0 if z >> R.
Right.
Now you something of the form
[tex]\left( 1 + a \right)^{-1/2},[/tex]
with [itex] |a| << 1. [/itex]
Can you write down the Taylor series expansion of the above expression?
I think I get:
1-x/2 - the first two orders. How does that sound?
Niles said:
I think I get:
Yes.
Now use all this in the original expression.
Then I get:
1/z - (1-z/2).
This is for inside the brackets. Then I multiply out and finish?
What is the motivation for the step?
Niles said:
Then I get:
1/z - (1-z/2).
Not quite. Recall that the "x" in your earlier equation is actually R/z.
Also, you have lost a factor of [tex]z^2[/tex] somewhere (the one that appears outside the brackets on the right-hand-side in George's post #6).
The motivation is to get something other than zero when you approximate this part of the expression:
[tex]
[/tex]
Cool, I get it now. Thanks for being so kind.
Suggested for: Evaluating electric field
