Evaluating expectation values
  • Thread starter KayDee01
KayDee01
[itex]f(x,y)=6a^{-5}xy^{2}[/itex] [itex]0≤x≤a[/itex] and [itex]0≤y≤a[/itex], [itex]0[/itex] elsewhere
Show that [itex]\overline{xy}=\overline{x}.\overline{y}[/itex]
[itex]\overline{x}=\int^{∞}_{-∞}{x.f(x)dx}[/itex]
[itex]=\int^{a}_{0}{x.6a^{-5}xy^{2}dx}[/itex]
[itex]=6a^{-5}\int^{a}_{0}{x^{2}y^{2}dx}[/itex]
[itex]=6a^{-5}[/itex][itex]\frac{1}{3}a^{3}y^{2}[/itex]
[itex]=2a^{-2}y^{2}[/itex]
Following the same process I get [itex]\overline{y}=\frac{3}{2}a^{-1}x^{2}[/itex]
But when it comes to [itex]\overline{xy}[/itex] I'm not really sure how to approach it
Answers and Replies
LeonhardEu
33
You found correcly x¯. Do the same for y and xy and complete your proof. What is your problem?
KayDee01
Sorry, I submitted the question to early and had to add the rest of the problem. I'm not sure what the [itex]\overline{xy}[/itex] integral should look like.
KayDee01
I tried [itex]\overline{xy}=\int^{∞}_{-∞}{x.y.f(x,y)dx}[/itex]
[itex]=\int^{a}_{0}\int^{a}_{0}{x.y.6a^{-5}xy^{2}dx}[/itex]
[itex]=\int^{a}_{0}\int^{a}_{0}{6a^{-5}x^{2}y^{3}dx}[/itex]
[itex]=\frac{1}{2}a^{2}=/=\overline{x}.\overline{y}[/itex]
KayDee01
I tried
[itex]=\frac{1}{2}a^{2}[/itex]
which does not equal [itex]\overline{x}.\overline{y}[/itex]
LeonhardEu
33
Your y¯ has a minor arithmetical mistake but you can find it. And for your major problem: d(xy) = ydx + xdy. Tell me when you have this ;)
Edit: It's not a double integral. It is one dimensional.
KayDee01
I see me mistake with [itex]\overline{y}[/itex], the x shouldn't be squared right?
If d(x,y)=xdy+ydx. Surely I end up with [itex]\int{xy.f(x,y)d(xy)}=\int{x^{2}y.f(x,y)dy}+\int{xy^{2}.f(x,y)dx}[/itex]
And I still can't get that to equal [itex]\overline{x}.\overline{y}[/itex]
statdad
1,495
36
This is an expected value problem? Try evaluating
[tex]
\int_0^a \int_0^a xy f(x,y) \, dx dy
[/tex]
again. This
"And for your major problem: d(xy) = ydx + xdy."
has nothing to do with the problem.
HallsofIvy
43,021
970
The first thing you need to do is define your terms! Your "[itex]\overline{x}[/itex]" is "the mean value of x for fixed y" and for "[itex]\overline{y}[/itex]" is "the mean value of y for fixed x". Since the first is a function of y and the second a function of x, their product can't possibly be equal to [itex]\overline{xy}[/itex] which is a number.
KayDee01
[tex]
[/tex]
again. This
I did this integral and got [itex]\frac{1}{2}a^{2}[/itex] which doesn't equal [itex]\overline{x}.\overline{y}[/itex] as I am trying to prove. The double integral will always eliminate the variables x and y from the equation. But [itex]\overline{x}.\overline{y}[/itex] has the variables in it.
How do I overcome this?
CAF123
88
Your ##\overline{xy}## is correct, so your error is in evaluating ##\overline{x}## and ##\overline{y}##. An expectation calculation should return a number.
HallsofIvy
43,021
970
Yes, which means that either your definitions (of [itex]\overline{x}[/itex], [itex]\overline{y}[/itex], and/or [itex]\overline{xy}[/itex] are wrong or [itex]\overline{x}\overline{y}[/itex] is NOT equal to [itex]\overline{xy}[/itex].
You might want to consider the possibility that the correct definition of [itex]\overline{u}[/itex] for any function u, of x and y, is [itex]\int\int u f(x,y)dydx[/itex] so that, in particular, [itex]\overline{x}= \int_0^a\int_0^a x f(x,y)dydx[/itex], NOT "[itex]\int_0^a xf(x,y)dx[/itex]".
(You also posted this under "precalculus homework". Do not do that. Double posting can get you banned.)
KayDee01
Using that definition of [itex]\overline{u}[/itex] I got them to equal one another :) Problem solved!
And thanks for the warning about double posting, I won't be doing that again.
jtbell
Mentor
15,944
4,611
The two threads have been merged. As HallsOfIvy noted, please post a question only once. If we think it really belongs in a different forum, we'll move it.
Ray Vickson
Dearly Missed
10,706
1,722
In addition to what others have said: I don't know if you have yet met with the concept of independence, but this problem fits that profile.
You can write your bivariate density f(x,y) as a product of two univariate densities g(x) and h(y):
[tex] f(x,y) = 6a^{-5}xy^{2} = (2 a^{-2} x) ( 3 a^{-3} y^2) = g(x) h(y), 0 \leq x,y \leq a. [/tex]
Here the individual factors ##g(x) = 2 a^{-2} x## and ##h(y) = 2 a^{-3} y^2## are both univariate probability densities of random variables ##X, Y## on ##[0,a]##: they are ≥ 0 and integrate to 1. There is a general theorem that ##E(XY) = EX \cdot EY## if ##X## and ##Y## are independent. You have shown one special case of this. Note: ##EX## is the expectation of ##X##, and is the same as what you call ##\bar{X}##.
Suggested for: Evaluating expectation values
  • Last Post
  • Last Post
  • Last Post
