Evaluating limits
Evaluate the following limit or explain why it does not exist:
limx→∞ 24x+1 + 52x+1 / 25x + (1/8)6x
I know there is the method where you divide through by the highest term in the denominator, but can that be applied here?
Answers and Replies
scottdave
Insights Author
1,813
775
So is it really something like this?
$$\frac {24^{x+1} + 5^{2x+1}} {25^x + (1/8)^{6x}}$$
This is my guess as what you are trying to type.
Also, is x approaching zero or infinity? It looks like a degrees symbol.
Try using LaTeX. It is not too hard to learn and it makes it easier to read.
Here is a guide. https://www.physicsforums.com/help/latexhelp/
No, its how i posted it, not 24x+1
and x is approaching infinity just like in the original post...
But okay ill use it, I learned it for python notebooks awhile ago, just quicker to not use it
scottdave
Insights Author
1,813
775
Like this?
$$\frac {2^{4x+1} + 5^{2x+1}} {25^x + (1/8)^{6x}}$$
What I was getting at is: what is in the numerator and what is in denominator?
Like this?
yep thats it, just how i posted originally
Ray Vickson
Dearly Missed
10,706
1,722
You wrote
$$2^{4x+1} + \frac{5^{2x+1}}{25^x} + (1/8)^{6x} $$
If you really mean
$$\frac{2^{4x+1} + 5^{2x+1}}{25^x} + (1/8)^{6x}$$
or
$$\frac{2^{4x+1} + 5^{2x+1}}{25^x + (1/8)^{6x}}$$
then you need to use parentheses. An expression like "A+B/C+D" means ##A + \frac{B}{C} + D##, but "(A+B)/(C+D)" is unambiguously equal to ##\frac{A+B}{C+D}##, and "(A+B)/C+D" is unambiguously equal to ##\frac{A+B}{C} + D##.
If you really mean
or
Oh you're right, I should have actually used parentheses, i'll make sure I am clearer in the future. Any help with the question though?
Ray Vickson
Dearly Missed
10,706
1,722
Look at the dominant terms:
We have ##2^{4x+1} = 2 (2^4)^x = 2 \;16^x## and ##5^{2x+1} = 5 (5^2)^x = 5\; 25^x##. So, among the two terms in the numerator (##2\; 16^x## and ##5\; 25^x##), which dominates for ##x \to \infty##? We also have ##(1/8)^{6x} = (1/8^6)^x = 1/262144^x##, so which of the two terms in the denominator will dominate when ##x \to \infty##?
Likes Erenjaeger and scottdave
scottdave
Insights Author
1,813
775
Try rewriting 25 as 5^2. What is going to happen to the (1/8) term?
scottdave
Insights Author
1,813
775
Were you able to use our suggestions to arrive at an answer?
scottdave
Insights Author
1,813
775
You can use the brute force method - plug in increasingly large numbers for x to see if it is converging toward something.
I like to do this in a spreadsheet, as a check to see if I'm on the right track.
yeah the answer is 5
Related Threads on Evaluating limits
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
13K
