Evaluating undefined limits
  • Thread starter baki
baki
1. Evaluate
2. lim χ→0 [((χ+1)^1/3) -1] / χ
3. The hint is [a^2 + b^2 = (a+b)(a^2 + ab + b^2)].
But i don't get it how can that help me solve this because it is a cube root and not to the power of 3.
Without thinking about the hint, I have attempted it and i think it is undefined for the function.
Say f(x) is the function, so f(0) is undefined making the limit as x approaches 0 undefined as well.
is it correct??
Answers and Replies
Ray Vickson
Dearly Missed
10,706
1,722
1. Evaluate
is it correct??
The hint is incorrect: a^2 + b^2 has 'a' and 'b' to the second power, while the right-hand-side has them to the third power. A correct hint would be a^3 - b^3 = (a-b)(a^2 + ab + b^2).
Think of setting y = (x+1)^(1/3), so the numerator of your expression is y-1. Can you see how to relate y-1 to y^3 - 1? Can you see how to write the denominator (x) in terms of y? Can you see what happens to y when x --> 0?
RGV
micromass
Staff Emeritus
Insights Author
22,129
3,302
That's one possibility and it works fine.
But I prefer to multiply numerator and denominator with [itex]a^2+ab+b^2[/itex] for suitable a and b. What do you get if you use the (correct version of the) hint?
baki
sorry I was wrong, the hint is: a^3 - b^3 = (a-b)(a^2 + ab + b^2)
Ok, I did L'hopitals rule to derive the formula, until I am able to get a value from substituting zero in place of x. My answer came to 1/3. But still the hint had nothing to do with it.
Are you saying for me to do the opposite operation??
SammyS
Staff Emeritus
1,167
Here is how the hint might be used:
The numerator [itex]\sqrt[3]{x+1}-1[/itex]. If you could get an equivalent expression with a numerator of [itex]\displaystyle \left(\sqrt[3]{x+1}\right)^3-1^3\,,[/itex] that would allow major simplification including cancelling a factor that goes to zero in the numerator & denominator.
Use the hint to find out what you need to multiply [itex]\sqrt[3]{x+1}-1[/itex] by in order to get [itex]\displaystyle \left(\sqrt[3]{x+1}\right)^3-1^3\ .[/itex]
By the way, welcome to PF!
baki
so then I would have to multiply it with ([itex]\sqrt[3]{x+1}[/itex])^2 + [itex]\sqrt[3]{x+1}[/itex] +1
and then do the same with the numerator??
is it??
and afterwards derive it???
SammyS
Staff Emeritus
1,167
is it??
No, you should not need to use L'Hôpital's rule.
Just multiply the numerator & denominator by [itex]\displaystyle \left(\sqrt[3]{x+1\ }\right)^2+\sqrt[3]{x+1\ }+1\ .[/itex] Then simplify.
baki
oh YES
solved!
other than simplifying we can just substitute 0, right?
Suggested for: Evaluating undefined limits
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
