• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Evaluation trig functions
  • Thread starter Nyasha
1. Homework Statement
[tex]cos(ArcSec(-\sqrt2+\frac{\pi}{4})[/tex]
3. The Attempt at a Solution
[tex]cos(ArcSec(-\sqrt2+\frac{\sqrt2}{2})[/tex]
In order to solve this problem how do l deal with the [tex]\frac{\pi}{4}[/tex]. Is it correct to substitute [tex]\frac{\pi}{4}[/tex] with [tex]\frac{\sqrt2}{2}[/tex]
316
Hi Nyasha!
Why do you think that [tex]\frac{\pi}{4}\approx .785[/tex] is the same as [tex]\frac{\sqrt{2}}{2}\approx .707[/tex]?
You can however simplify cos(arcsec(...)).
127
Hi Nyasha!
So is this correct:
[tex]
cos(ArcSec(-\sqrt2+(0.785))
[/tex]
316
Well, you don't need to use decimal notation (and probably should not in this case), I was just trying to demonstrate that the two numbers are not the same.
What I was hinting at before: sec(x)=1/cos(x), so arcsec(x)=arccos(1/x) and also cos(arccos(x))=x by definition. Use this to simplify your expression.
127
I can evaluate this thing without the [tex] \frac{\pi}{4} [/tex] by the assistance of of the principal range of arcsec and a diagram. I just am just getting confused with the [tex]\frac{\pi}{4}[/tex].
127
Thanks, l have solved the question.
[itex]\text{Using pricinpal values: }\:\text{arcsec}\left(\text{-}\sqrt{2}\right) \:=\:\frac{3\pi}{4}[/itex]
And then add the [itex]\frac{3\pi}{4}[/itex] to the[itex]\frac{\pi}{4}[/itex]
316
So it really was [tex]\text{cos}(\text{arcsec}(-\sqrt{2})+\frac{\pi}{4})[/tex]? Otherwise, it is not correct.
127
Yes it was :
[tex]\{cos}(\text{arcsec}(-\sqrt{2})+\frac{\pi}{4})[/tex]
It seemed as if l had copied the thing wrongly.
However,it seems as if l have solved it.
Related Threads for: Evaluation trig functions
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
