Understanding Even & Odd Functions: Questions Answered
In summary, we discussed why x(t)+x(-t) is always even, regardless of whether x(t) is even or odd. We also clarified that the unit step function does not affect the value at 0, and that the - in front of t in x(-t) reverses the direction of the shift.
tina_singh
1)-why is x(t)+x(-t) always even??..no matter if x(t) even or odd?
2)-when we talk about unit step function...u(t)..and we add..u(t)+u(-t)..the value of both is 1 at t=0..so does'n't that gets added twice??..and it becomes 2 at t=0...
3)when we have x(-t) and we time shift it say x(-t-3) it shifts toward the -ve t axis.. where as x(t-3) the function is shifted on the + axis..why is it so??
i would be really greatful if you can help me out with the above 3 doubts..
Mathematics news on Phys.org
What did you try to answer this??
For the first, fill in -a in x(t)+x(-t) and see if
[tex]x(-a)+x(-(-a))=x(a)+x(-a)[/tex]
For the second one. It actually never matters what the unit step function is in 0. So saying that u(t)+u(-t)=2 in 0, is correct, but it doesn't matter.
Note that a lot of people choose that the unit step function is 0, or 1/2 in 0.
The third one. We actually have a function y(t)=x(-t). Then x(-t-3)=y(t+3). So it makes sense that it gets shifted to the other side.
okh..thanks for answering..i got the first 2 parts...
buh i m still a little confuse about the third...see when we say there are 2 functions x(t) and x(t-2) it means x(t-2) is delayed by 2 sec with respect to x(t) therefore it shifts in the positive x direction.. does'n't the same apply for x(-t) and x(-t-2) the second function is time delayed by 2 secs with respect to the first so even it should shift to the positive x axis..isn't it?
The - in front of the t reverses the direction. So shifting towards the positive axis becomes shifting towards the negative axis and vice versa.
1) The sum of two even functions or two odd functions will always result in an even function. This is because an even function is symmetrical about the y-axis, meaning that it is unchanged when x is replaced with -x. Similarly, an odd function is symmetrical about the origin, meaning that it is unchanged when both x and y are replaced with -x and -y. When we add an even function x(t) with an odd function x(-t), the result will be symmetrical about the y-axis and therefore an even function.
2) The unit step function u(t) is defined as 0 for t < 0 and 1 for t ≥ 0. When we add u(t) and u(-t), we are essentially adding two functions that are both 1 at t = 0. However, we must remember that the unit step function is only defined for t ≥ 0. Therefore, at t = 0, the function u(-t) is undefined and is not included in the addition. This means that the result will still be 1 at t = 0, and not 2.
3) When we time shift a function, we are essentially shifting the entire function along the x-axis. So when we have x(-t) and we shift it by -3, we are shifting the function towards the negative x-axis. On the other hand, when we have x(t-3) and we shift it by -3, the function is shifted towards the positive x-axis. This is because the negative sign in the time shift represents a shift in the opposite direction of the x-axis. So in the first case, the function is shifted towards the negative x-axis, and in the second case, it is shifted towards the positive x-axis.
1. What is an even function?
An even function is a mathematical function where the output values remain unchanged when the input values are replaced by their negative counterparts. In other words, if f(x) is an even function, then f(x) = f(-x).
2. What is an odd function?
An odd function is a mathematical function where the output values change sign when the input values are replaced by their negative counterparts. In other words, if f(x) is an odd function, then f(x) = -f(-x).
3. How can I tell if a function is even or odd?
To determine if a function is even or odd, you can use the symmetry test. If the function remains unchanged when the input values are replaced by their negative counterparts, then it is an even function. If the function changes sign when the input values are replaced by their negative counterparts, then it is an odd function.
4. What are some examples of even and odd functions?
Examples of even functions include f(x) = x^2, f(x) = |x|, and f(x) = cos(x). Examples of odd functions include f(x) = x^3, f(x) = sin(x), and f(x) = tan(x).
5. Why are even and odd functions important?
Even and odd functions have many practical applications in mathematics and science, particularly in the fields of geometry, physics, and engineering. They are also important in understanding the properties and behavior of various mathematical functions and equations.
  • General Math
  • General Math
  • General Math
  • General Math
  • General Math
  • Differential Equations
