Odd or Even: f(x)=6x(1-x)
In summary, the conversation discusses how to determine if a function is odd or even. It suggests two approaches - checking the function's properties and plotting its graph. It is also mentioned that a function can be both, neither, or either odd or even.
hofoen
Is this function odd or even:
[tex]f(x) = 6x(1-x)[/tex]
Mathematics news on Phys.org
If it is odd, then f(-x) = -f(x)
If it is even, then f(-x) = f(x).
You can check which one it satisfies.
Note that it can be neither (i.e. if it is not odd, that doesn't necessarily mean it's even).
Another approach is, you can plot your function as a graph for different values of x say from -10 to 10. Now you see the graph of f(x) , whether it is symmetrical about y axis. If you see mirror image of function about y-axis it is even function and if you see negative reflection it is odd and if it is neither, then it is neither even nor odd function.
hofoen said:
Is this function odd or even.
No, it isn't.
Once the OP has settled the answer to his/her original question:
Let [itex]x = \frac{1}{2} + y[/itex]. In terms of y is the function [itex]g(y) = f(1/2+y)[/itex] even or odd?
(Note that this does not really mean that f(x) is even or odd if g(y) is even or odd, since technically speaking f and g are not the same function, even though they are just the translations of each other).
Hofoen, please note that a function can be even or odd or neither or both.
That iws uart's point!
1. What is the equation for "Odd or Even: f(x)=6x(1-x)"?
The equation is f(x) = 6x(1-x).
2. Is the function f(x)=6x(1-x) odd or even?
The function is neither odd nor even, as it does not satisfy the conditions for either type of function.
3. How do you determine if a function is odd or even?
A function is odd if f(-x) = -f(x) and even if f(-x) = f(x). To determine this, substitute -x for x in the equation and see if it simplifies to the same function or its negative.
4. What is the range of the function f(x)=6x(1-x)?
The range of the function is all real numbers from 0 to 3, since the function is a parabola that opens downward and its vertex is at (0,0).
5. Can you provide a graph of the function f(x)=6x(1-x)?
Yes, here is a graph of the function:
Graph of f(x)=6x(1-x)
  • General Math
  • General Math
  • General Math
  • General Math
  • General Math
