Everything moving at c
  • Thread starter RAD4921
RAD4921
347
In the book "The Elegant Universe" Brian Green says Einstein once said everything in the universe is moving at the speed of light. How can this be? I thought bodies with mass couldn't reach c.
Answers and Replies
JesseM
Greene isn't talking about ordinary speed, he's using a sort of idiosyncratic definition of "speed through spacetime" which personally I think is more misleading than helpful--see this thread for more details.
εllipse
196
Could you provide a page number?
I assume this is a misunderstanding about Greene's talking about "speed through time". Greene says you can think of everything moving at the speed of light, but things that don't really move at the speed of light are experiencing most of their "motion" through time rather than space. This can be confusing terminology because the idea of "motion" usually means the amount of space covered in a certain amount of time, but Greene is appealing to the fact that time flows in a direction as well.
edit: I've never read anything from Einstein that stated anything close to "everything moves at c", and I would be surprised if someone dug up an example of Einstein using that terminology. If Greene says "Einstein said everything moves at c," he most likely meant Einstein's theories can be interpreted in such a way.
yogi
1,525
Several authors have used this metaphore - it gives you a simple derivation of the transforms. But like Ellipse - I cannot find any reference to it in Einstein's original writings
Mortimer
142
The velocity 4-vector, i.e. the "velocity" in 4D Minkowski space-time has an invariant magnitude [itex]c[/itex] for all objects. The point is however that this 4-vector cannot be interpreted as a normal velocity like velocities in space. The vector is defined as [tex]\frac{dx_\mu}{d\tau}[/tex] whereas normal spatial velocities are [tex]\frac{dx}{dt}[/tex]. ([itex]\tau[/itex] is proper time, defined as [itex]\tau=t/\gamma[/itex]).
What Greene does is rewriting the components of this 4-vector from the usual Minkowski form (+---) into Euclidean form (++++) which also changes the spatial velocity components in normal velocity components [tex]\frac{dx}{dt}[/tex]. You then end up with a temporal velocity component [tex]c\frac{d\tau}{dt}[/tex] which is supposed to be the velocity through the time dimension. Greene's approach is common for what is called "Euclidean relativity", a not very well known alternative mathematical framework for the usual Minkowski framework.
RAD4921
347
Dimensions and geometry
I think I can understand what you are saying. Green was using 3 dimensions to explain a 4 dimensional phenomena.
CBJammin103
By "everything is moving at c," a 4D spacetime is referred to rather than a 3D traditional space. Basically, if we are not moving in the first three dimensions relative to an outside observer, then we are moving completely in the 4th dimension. As we move closer to a total of c in the first 3 dimensions, though, less of our "4D-velocity" is directed in the "t" direction and therefore we appear to experience less time to an outside observer.
Basically, this is just a simple way to try to explain the effects of relativity; that is, if we move at a velocity closer to c in space, we move at a slower "velocity" through time.
Fallaciousmiles
If my guess is correct, i believe that it was an example about the limit of going to close to the speed of light and its effect on the dilation of time.
With an analogy of a fast moving vehicle trying to calculate its maximum speed by going through a series of test runs.
The first direction taken from point A to B taken to be parrallel to an axis, and the rest of the runs be slightly deviated from the original axis (cause by human error) causing a slight slower time achieved than the rest of the runs.
Eg
y-axis |
|_______ x-axis
With either of the Axis being Space and Time
With the above analogy being given then more speed less time and less speed more time
I hope i am understandable. Cause i have the above book though. Kinda slow to digest if you are a bit of a beginner(me) and you try to understand everythig in the book =P
Suggested for: Everything moving at c
  • Last Post
  • Last Post
  • Last Post
13K
  • Last Post
  • Last Post
  • Last Post
