Exact differential equation
  • Thread starter mahler1
Homework Statement .
Solve the differential equation: ##(3x^2-y^2)dy-2xydx=0##.
The attempt at a solution.
I thought this was an exact differential equation. If I call ##M(x,y)=-2xy## and ##N(x,y)=3x^2-y^2##, then the ODE is an exact differential equation if and only if ##\frac{\partial M}{\partial y}= \frac{\partial N}{\partial x}##. Now, when I compute these two partial derivatives, ##\frac{\partial M}{\partial y}=-2x## and ##\frac{\partial N}{\partial x}=6x## which are clearly different. Am I doing something wrong or is it just that this equation is not exact?
Answers and Replies
6,734
Looks to me to be not exact.
Yes, I've looked up in an ODE textbook and I've found that you can reduce this equation to an exact differential equation by something called "the integrating factor". Thanks anyway.
STEMucator
2,075
140
I find it helps writing the equation like so to avoid negative sign errors:
##(3x^2-y^2)dy + (-2xy)dx=0##
I can see an integrating factor in your equation that relies only on ##x##. Using this integrating factor, you might be able to turn this equation into an exact equation. Then it is easily solvable.
Thanks, I've been able to reduce the equation to an exact equation by finding ##μ(x)##.
Related Threads on Exact differential equation
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
