Exam II Questions
  • Thread starter Alt+F4
  • #51
306
Alt+F4 said:
one more,
http://online.physics.uiuc.edu/cgi/courses/shell/phys102/fall06/prep2a.pl?practice/exam2/sp06 [Broken]
question 24.
i did this like 20 times in other exams, i dont know why it doesnt work here but
F= ILBSintheta = MG
(X)(.1)(.5) = (9.8)(1)
X = 196Amps, but the answer is 98 Amps what gives?
is this the same idea on how one side isnt really contibuitng?
  • #52
OlderDan
3,021
I thought you had already resolved this one (#24). For this one you only used one side of the loop when you should have used both sides. Both sides contribute to the torque, so only half the current you calculated is needed.
  • #53
306
OlderDan said:
I thought you had already resolved this one (#24). For this one you only used one side of the loop when you should have used both sides. Both sides contribute to the torqe, so only half the current you calculated is needed.
silly me, thanks alot for your help like seriously. My TA's arent even that helpful
  • #54
306
Alt+F4 said:
Question 16 please :)
http://online.physics.uiuc.edu/cgi/courses/shell/phys102/fall06/prep2a.pl?practice/exam2/fa05 [Broken]
So i tried doing it on Calculator but since sin180 = 0 i get 0
hmm all right so i graphed this, Does it matter if calc is in radian or degree?
  • #55
306
http://online.physics.uiuc.edu/cgi/courses/shell/phys102/fall06/prep2a.pl?practice/exam2/su06 [Broken]
Question 20
Finger Curl with current
B Field points Down
I woulda picked Rotates it so that the right side comes out of the page and the left goes in.
  • #56
306
All right last question untill Nov 23rd i think
http://online.physics.uiuc.edu/cgi/courses/shell/phys102/fall06/prep2a.pl?practice/exam2/fa03 [Broken]
Question 21
So W = 2piF = (2*3.14*580*10^3) = 3.6E6
>and 1 / ( sqrt 1*10^-3 * .06*10^-6) = 1.2909 E5
what am i doing wrong
  • #57
OlderDan
3,021
Question 21
You are supposed to be finding the value of C that will make the resonant frequency of the circuit the desired broadcast frequency. How does C affect the net capacitance of the circuit?
  • #58
OlderDan
3,021
Question 20
B Field points Down
Currents parallel to magnetic fields experience no force. Currents at right angles do.
  • #59
OlderDan
3,021
Yes. Always use radians for these time dependent problems. If they ask for phase in degrees, convert it from radians. If they give phase in degrees, convert it to radians. Angular frequency is always in radians/sec.
  • #60
306
all right but for some reason when i graph in Radian mode i seriously get like -6 and -5 values unless i am doing something wrong with it
  • #61
306
All right i need a CLarifcation on this one
Question 21
The angle i pick should be what to the field line? i wanted to do 90-22.5 but that wont work. Thanks alot
  • #62
306
Last Problem then im off to exam, Thanks Olderdan and whoever else that helped me. Really appreciate it
Question 8
  • #63
OlderDan
3,021
Question 21
Rotate through the small angle from the direction of v to the direction of B. It is just 22.5
  • #64
OlderDan
3,021
Question 8
Flux is
Φ = BAcosθ where θ is the angle between the loop normal and B. θ = 30 degrees
The only thing changing is B, so
dΦ/dt = (Acosθ)dB/dt
  • #65
306
Can't you take the exam for me?
  • #66
OlderDan
3,021
What exam are you taking? Could I bring all my reference materials with me? I still remember how to do this stuff, but it sure is nice having the references readily available when you don't remember the exact formulas, values of constants, etc.
  • #67
306
nope no refrence but u could program ur calculator. Im takin physics exam in like 2 hrs.
Related Threads on Exam II Questions
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
