• Support PF! Buy your school textbooks, materials and every day products Here!
Exam Questions- Need Help Please
  • Thread starter RaidersFan
1. Homework Statement
a 47kg women balances on one heel of a high heeled show. if the heel has a radius of 1.4cm what pressure does she exert on the floor?
2. Homework Equations
rho=m
v
3. The Attempt at a Solution
= 47kg = 33.5
1.4cm
The pascal principle is used to operate a dentists chair. assume that the pressure everywhere in the fluid is 13.5 kpa. if the small cylinder(piston) has an area of 0.007m(squared) and the large cylinder(piston) has an area of 0.08m(squared) calculate the force on each cylinder.
i think the equation is f=af
a
=(3.14)(0.007)squared(13.5)
0.08(squared)
=.32
a gold nugget weighs 1.23N in air. when suspended from a string and submerged in water its apparent weight (T) is 1.09N. calculate the density of the gold nuggett.
density=mass
volume
= 1.23N
(3.14)r(squared) x h
water enters a cylindrical pipe 3.5cm in diameter at a speed of 1.6m/s. if the pipes diameter is suddenly reduced to 2.1cm, what is the max velocity of the water moving through the smaller pipe?
AV=AV
3.14(3.5)(1.6)=A(2.1)
air is pushed through a forced-air furnace duct at a speed of 4.7m/s. the duct is rectangular and measure 58cm by 23cm. how fast will air move through a smaller portion of the duct that is also rectangular and measures 35cm by 23cm.
AV=AV
3.14(58)V=23(4.7)
a force of 19N[E] pushes a box of mass 13.2kg across a level floor at a constant speed. calculate the coefficient of kinetic friction (,U) between the two surfaces.
,U=f
mg
= 19
13.2(9.80)
= 19
129
=0.14
129
i know its a lot of work there so you can do all of them or just 1 or how every many you want to. im just struggling on these questions and my exam is tomorrow and i really need some help so if you guys are able to help me out i would really appreciate it. thanks so much for doing this guys. :smile:
oh and u can delete my other thread since i read cristos post.
Answers and Replies
In response to your first question:
Pressure is defined as a force per unit area. You are given mass and, assuming the woman is on Earth, the force exerted by her shoe can easily be found by basic mechanics.
Related Threads for: Exam Questions- Need Help Please
  • Last Post
  • Last Post
  • Last Post
