How do we apply the Friedman solution to a fluid with constant pressure and energy density?
  • Thread starter Rev Prez
  • Tags
    Example
In summary, the Friedman solution for a fluid with a given pressure and energy density leads to: -H^2 = \left(\frac{\dot{a}}{a}\right)^2 = \frac{8 \pi G}{3}\rho + \frac{\Lambda}{3} - \frac{k}{a^2}
Rev Prez
29
Looking at the Friedman solution for a fluid with a given pressure and energy density, we have:
[tex]H^2 = \left(\frac{\dot{a}}{a}\right)^2 = \frac{8 \pi G}{3}\rho + \frac{\Lambda}{3} - \frac{k}{a^2}[/tex]
Would someone mind walking me through how we arrive at a?
Rev Prez
Astronomy news on Phys.org
From the assumption that the universe is isotropic we are lead immediately to the Robertson-Walker metric:
[tex] ds^2 = c^2dt^2 + a(t) [ dr^2 + S_k(r) d\Omega^2 ] [/tex]
K is a constant either -1, 0, +1.
If k = +1 , the function S(r) = sin(r).
If k = -1, S(r) = sinh(r).
k = 0 implies S(r) = r.
By the way, omega is shorthand for some angular metric components, look it up under "hypersphere" at www.mathworld.com
Anyway, from this metric, along with the stress-energy tensor for a perfect fluid:
[tex] T_{\alpha\beta} = P g_{\alpha\beta} - (P - \rho)U_\alpha U_\beta [/tex]
(P is pressure, u is four velocity, rho is density, and g is the metric tensor)
We insert both of these guys into the einstein field equations (remember the einstein tensor G is just a bunch of derivatives of the RW metric):
[tex] G_{\alpha\beta} = \frac{8 \pi G}{c^2} T_{\alpha\beta} [/tex]
Then solve for a(t) to get the freidmann equation. It is all very do-able, but it takes at least half an hour.
Okay.
1. [tex]d\Omega = d\theta^2 + \sin^2(\theta)d\phi [/tex].
2. Shouldn't [tex]S_k(r)[/tex] take on the same units as dr (as [tex]d\Omega[/tex] is dimensionless)? In which case, as is indicated http://en.wikipedia.org/wiki/Friedmann-Lema%EEtre-Robertson-Walker, we should multiply by the mag of the curvature radius. I'm not being facetious, but its easy to get lost when you're not quite clear on the unit constant convention used.
3. The codomain of k is restricted to -1, 0, 1, or is this just a convenient choice since we're more or less concerned with whether the large scale structure is closed, flat or hyperbolic?
Now this is where I should've started asking questions. What process do you go through starting with "homogenous, isotropic universe" to get a tensor description of it? I understand intuitively what it means, but I would love to know how you reason out a perfect fluid's formal representation.
I can guess that:
1. Because FLRW is for an isotropic, homogenous universe, P and [tex]\rho[/tex] are assumed constant...
...and...
2. for an observer at rest with the fluid, the equation reduces to [tex]T_{\alpha\beta} = P g_{\alpha\beta}[/tex]
But where do you get [tex](P - \rho)[/tex]?
Thanks for your help. I'll digest this and get back to the thread if I have more questions.
Rev Prez
It is much easier to look at the stress energy tensor for a perfect fluid in matric form than as:
But I don't know how to Latex format a matrix. I will describe the components in the rest frame of the fluid:
[tex]T_{00} = \rho c^2[/tex]
[tex] T_{11} = P_x[/tex]
[tex] T_{22} = P_y[/tex]
[tex] T_{33} = P_z[/tex]
And the rest (off diagonal) are zero. Remember that U is the four velocity, and in the rest frame of the fluid this is equal to c in the time direction. Also, remember pressure is stress.
Yes, an isotropic (simply connected) shape can only have one of three curvatures.
Okay, I got it. So check me here. In the fluid's rest frame, which a choice of units c = 1, the equation gives us just the energy density, correct?
Rev Prez
What are you using for g ? In the rest frame of the particle the metric tensor (g) is simply the flat metric of minkowski spacetime (16 components, all of them zero except g00 = -1 and g11=g22=g33=1).
U is a vector which is all zero accept for the zeroth component (time) which is c = 1.
Using these and the abstract equation, you should be able to construct the components of the stress-energy tensor of a perfect fluid (in its rest frame). (the diagonal terms I described.)
Just g00 = -1, everything else set to zero.
Since
[tex]g_{\alpha\beta} = -U_{\alpha}U_{\beta[/tex]
in the rest frame,
[tex]T_{\alpha\beta} = Pg_{\alpha\beta} - (P - \rho)U_{\alpha}U_{\beta}[/tex]
reduces to
[tex]T_{\alpha\beta} = \rho(U_{\alpha}U_{\beta})[/tex]
where all that remains is the energy density component in the time direction.
Right?
Rev Prez
I think I got it.
You will end up with [tex]diag(\rho, p, p, p)[/tex] for constant pressure and energy density and with c = 1. The [tex]U_{\alpha}U_{\beta}[/tex] term will give us the energy density in the time dimension and the metric term will give us the pressure in space.
Rev Prez
1. What is an example?
An example is a specific instance or illustration used to demonstrate a concept or idea.
2. Why are examples important?
Examples help to clarify and reinforce understanding of abstract or complex concepts. They also provide a practical application and context for theoretical information.
3. Can you give me an example, please?
Sure! For example, if I were explaining the concept of gravity, I could use the example of an apple falling from a tree to illustrate how objects are pulled towards the Earth.
4. How do you come up with examples?
Examples can be created through observation, experimentation, or by using existing examples from literature or real-world situations. It's important to choose relevant and clear examples that support the intended concept.
5. Can examples be used in all scientific fields?
Yes, examples are used in all scientific fields as a means of explaining and understanding concepts. They may vary in form depending on the field, but the purpose remains the same.
  • Astronomy and Astrophysics
