Expanding a function
  1. Jan 10, 2014 #1
    I have sometimes seen a function f being written as
    f \approx f_0 + \varepsilon f_1(x)+ \varepsilon^2 f_2(x) + \ldots
    where [itex]f_0[/itex] is an equlibrium value and all higher-order terms are non-equilibrium values (not derivates!). The assumption has always been that [itex]\varepsilon \ll 1[/itex].
    My question is: Mathematically, I guess we are expanding the function f around its equlibrium value. But when I look at the expression for a Taylor expansion, I can't make this fit with anything.
    Are we non-mathematicians even allowed to write the function like this?
  3. Jan 10, 2014 #2
    Thank you for using the (much prettier looking) \varepsilon for your epsilons. :tongue:
    Well, us math-folk sometimes have a dislike for approximations and what you have written doesn't specify a domain or codomain (so we wouldn't technically call it a function by strict definition), but I see no other reason why you couldn't do that.
    If your ##\{f_i\}## follow some sort of pattern, we can probably solve the limit $$f(x)=\lim_{n\rightarrow+\infty}\sum_{0\leq i\leq n}\varepsilon^if_i(x).$$
    Can you give us more information? I'm interested in understanding what you're doing here.
  4. Jan 10, 2014 #3
    That looks like an asymptotic expansion, not a Taylor series. In such expansions we usually don't care whether
    \lim_{N \to \infty} \sum_{n=0}^N \epsilon^n f_n(x)
    even exists; what we're interested in is whether [itex]\sum_{n=0}^N \epsilon^n f_n(x)[/itex] for some finite [itex]N[/itex] is a sufficiently good approximation to some [itex]F(x,\epsilon)[/itex] when [itex]|\epsilon| \ll 1[/itex].
    Generally the idea is to exploit a small parameter to turn a problem we can't solve analytically for [itex]F(x,\epsilon)[/itex] into a series of problems we can solve for the [itex]f_n[/itex].
  5. Jan 10, 2014 #4
    Thanks for the help so far, both of you.
    That is exactly how it is used in my case (a Chapman-Enskog expansion). But doesn't this require that the various terms [itex]f_n[/itex] are somewhat independent, so we can solve for each order independently?
  6. Jan 10, 2014 #5
    Suppose you have a function of the two variables ε and x, f(ε,x) and you expand in a Taylor series in ε about ε=0. Then you get:
    [tex]f(ε,x)=f(0,x)+ε\left(\frac{\partial f(ε,x)}{\partial ε}\right)_{ε=0}+\frac{ε^2}{2}\left(\frac{\partial^2 f(ε,x)}{\partial ε^2}\right)_{ε=0}+ ...[/tex]
    Then you can identify the functions in your summations with the partial derivative terms in this series.
  7. Jan 11, 2014 #6
    The problem for [itex]f_n[/itex] should depend only on [itex]f_0, \dots, f_{n-1}[/itex], so that one can work forward from [itex]f_0[/itex].
Have something to add?
Draft saved Draft deleted
