Expanding Universe: Verifying Space Expansion Through Galaxies
In summary, the expansion of space is determined by observing the redshift of distant galaxies, which indicates that the universe is expanding. This is supported by other evidence such as the cosmic microwave background, the recession of galaxies, and the homogeneity and isotropy of the universe. The current inflationary cosmology also supports the idea of expansion. While it is common to talk about space itself expanding, the consensus is that space is just a part of the space-time framework and cannot expand or bend. The big bang is not a point in space, but a point in time.
ggolu2
How one can say that the space is expanding by just verifying that the galaxies are speeding away from each other?
Space news on Phys.org
Galaxies speeding away from each other is what it MEANS when you say that the universe is expanding. I guess I don't understand your question.
We can't. Not by just looking at galaxies. There are several key pieces of evidence that add up, namely the CMB, the observed recession of galaxies, the homogeneous and isotropic nature of the universe at the largest scales, the prediction of primordial elements created in the early universe, and more.
We can predict that the universe must be expanding by looking at the sky. The sky is only as hot and bright as the Sun's surface where the Sun is located. If the universe was static and eternal, it would be as hot and bright in every direction, all star's light would sum without energy loss during travel. (Olber's paradox; http://en.wikipedia.org/wiki/Olbers'_paradox )
When we use that cosmological redshift to predict the same but seen as the average apparent velocity of galaxies, which is receeding, we have to add the constraint that the universe is homogeneous and isotropic. That constraint is given by the simplest universes that general relativity produces, so called FRW universes, and that is the kind of universe we live in. Then we know that it happens irrespective of the observer's location, and hence is a result of spacetime expansion rather than an unlikely conspiracy among actually traveling galaxies (that they don't like our breath, say, and the farther out they are the faster they want to escape it :L).
But the evidence is much firmer than that as Drakkith describes. Going back to redshifts, there is also a natural velocity "noise" added on the cosmological expansion, signifying the gravitational effects of the superclusters like our own Laniakea [ http://www.nature.com/news/earth-s-new-address-solar-system-milky-way-laniakea-1.15819 ]. So we know they are separate effects.
And to top that the current inflationary cosmology makes the expansion inevitable. You can't predict a self-consistent universe, consistency among our observations, without it.
The expansion of space is not a reference to the speed of galaxies but to the consistencies in red shift of element spectra from distant galaxies. Because of the red shift being proportionally the same is every direction the red shift comunicates that space itself is expanding. If space was not expanding the proportional redshift would not occur. However red/blue shift is used to determined relative velocities to earth.
Clayjay said:
The expansion of space is not a reference to the speed of galaxies ...
Actually, I think it IS, since "space" isn't really doing anything ... things are just getting farther apart in the framework of space-time. Google "metric expansion" for more. I know it's common to TALK as though space itself were expanding, but the consensus seems to be that space is not a thing that can bend/warp/expand, etc., it's just a part of the space-time framework in which things happen.
(Assuming Big Bang cosmology) Before the BB there was no space - time. "The center of expansion today is every point in the universe because every point was the same point in the beginning". (Allen Sandage)
Space is doing much more than expanding, it is full of virtual particles. Also space does bend due to gravity.
So, as mentioned in this forum - the big bang did not happen as a place in space but as a place in time.
There is no space outside of space-time. Theoretically speaking in BB cosmology.
1. What is the expanding universe theory?
The expanding universe theory, also known as the Big Bang theory, is the scientific explanation for the origin and evolution of the universe. It states that the universe began as a single point of infinite density and has been expanding ever since.
2. How is the expansion of the universe measured?
The expansion of the universe is measured through the observation of distant galaxies and their redshift. Redshift occurs when light from an object is stretched as it travels through expanding space, causing it to appear more red. By measuring the redshift of galaxies, scientists can determine how fast they are moving away from us and the rate of expansion of the universe.
3. Can the expansion of the universe be observed in real-time?
No, the expansion of the universe occurs on a very large scale and cannot be observed in real-time. However, through the use of powerful telescopes and advanced technology, scientists can observe and measure the effects of the expansion on distant galaxies.
4. How does the expansion of the universe affect the movement of galaxies?
The expansion of the universe causes galaxies to move away from each other at an accelerating rate. This is due to the continuous stretching and expanding of space between them. The larger the distance between galaxies, the faster they will be moving away from each other.
5. What evidence supports the theory of an expanding universe?
There are several pieces of evidence that support the theory of an expanding universe. These include the observation of redshift in distant galaxies, the cosmic microwave background radiation, and the distribution of elements in the universe. Additionally, the existence of dark energy, a mysterious force that is causing the expansion of the universe to accelerate, further supports the theory.
  • Cosmology
