Expectation value of a vector?
L and N respectivelyIn summary, for a particle in a potential V(r), the rate of change of the expectation value of the orbital angular momentum L is equal to the expectation value of the torque N, where N is the vector product of r and (-del V). This equation can be written out in terms of the components of L and N, with the expectation values of the x components being equal to the time derivative of the expectation value of the x component of L, and so on for the y and z components. Therefore, it is possible for a vector to have an expectation value, as long as the components of the vector are represented by operators.
phrygian
80
Prove that for a particle in a potential V(r) the rate of change of the expectation value of the orbital angular momentum L is equal to the expectation value of the torque:
d/dt <L> = <N>
Where N = r x(-del V)
N, r, and L are vectors.
I know how to solve this, but do not understand the equation. How can a vector have an expectation value? A vector is not an operator, I thought only an operator can have an expectation value?
Thanks for the help
That's three equations in one. You write out the components and the expectation value of the x component of the torque will be equal to the time derivative of the expectation value of Lx and so on.
In other words:
[tex]d/dt \begin{pmatrix}\langle L_x\rangle\\ \langle L_y\rangle\\ \langle L_z\rangle \end{pmatrix}= \begin{pmatrix}\langle N_x\rangle \\\langle N_y\rangle \\ \langle N_z\rangle \end{pmatrix}[/tex]
where [itex]L_x,L_y,L_z,N_x,N_y,N_z[/itex] are operators
1. What is the expectation value of a vector?
The expectation value of a vector is a mathematical concept that refers to the average value of a vector when it is measured multiple times. It is represented by the symbol ⟨V⟩ and is calculated by taking the dot product of the vector with itself and then taking the square root.
2. How is the expectation value of a vector calculated?
The expectation value of a vector is calculated by taking the dot product of the vector with itself and then taking the square root. This can be represented by the formula ⟨V⟩ = √(V⋅V).
3. What does the expectation value of a vector tell us?
The expectation value of a vector tells us the average value of the vector when it is measured multiple times. It gives us an idea of what value we can expect to obtain when we measure the vector.
4. How is the expectation value of a vector related to uncertainty?
The expectation value of a vector is related to uncertainty in that it gives us an idea of the most probable value of the vector, but it does not tell us the exact value. The smaller the uncertainty, the closer the expectation value will be to the actual value of the vector.
5. Can the expectation value of a vector be negative?
Yes, the expectation value of a vector can be negative. This can occur when the vector has a mix of positive and negative values. The expectation value represents the average of these values and may be negative if they cancel each other out.
