• Support PF! Buy your school textbooks, materials and every day products Here!
Expectation Value of Momentum
  • Thread starter Feldoh
Consider a wave function [tex]\psi (x,t) = R(x,t) exp(i S(x,t))[/tex] what is the expectation value of momentum?
[tex] <f(x)> = \int^{\infty}_{-\infty} \psi^* f(x) \psi dx[/tex]
[tex] \hat{p} = -i \hbar \frac{\partial}{\partial x} [/tex]
This is for an intro to modern class so I don't really have a formal background with eigenvalues/vectors yet so this is a bit confusing.
Can I just say that [tex] <p> = \int^{\infty}_{-\infty} \psi^{*} \hat{p} \psi dx = \int^{\infty}_{-\infty} \hat{p} \psi^{*} \psi dx[/tex] ?
If so by the normalization condition <p> = -i hbar which I don't think can be the case.
So...
[tex]<p> = \int^{\infty}_{-\infty} R exp(-i S) \hat{p} R exp(i S) dx[/tex]
[tex]= -i\hbar \int^{\infty}_{-\infty} R exp(-i S) * [R' exp(i S) + i R S' exp(i S)]dx [/tex]
[tex]= -i\hbar \int^{\infty}_{-\infty} R R' + i R^2 S' dx [/tex]
I don't really see anything from there...
I'm tempted to just say 0, but I'm not sure that the function being evaluated is odd.
Answers and Replies
CompuChip
4,302
47
No, you cannot.
The first equality is true, but the second is not. You cannot just pull an operator through a function, because
[tex]\psi^* \frac{\partial}{\partial x} \psi \neq \frac{\partial}{\partial x} \psi^* \psi[/tex]
which is ambiguous too, as it could mean either
[tex]\frac{\partial}{\partial x} \left( \psi^* \psi \right) = \frac{\partial \psi^*}{\partial x} \psi + \psi^* \frac{\partial\psi}{\partial x} [/tex]
or
[tex]\left( \frac{\partial}{\partial x} \psi^* \right) \psi[/tex]
Instead you just plug in the wave-function. Start by writing down what is
[tex]\hat p \psi(x, t) [/tex]
I all ready did apply the momentum operator like that in my derivation:
[tex]i\hbar [R' exp(i S) + i R S' exp(i S)][/tex]
I just assumed that the second expression was wrong and did it the (semi)correct way.
CompuChip
4,302
47
Ah, I see that now.
Yes you did it right.
The result isn't something very beautiful, but I suppose one would not expect that... after all the wave function depends on R and S, both of which are arbitrary functions on spacetime, so one cannot "predict" the expectation value on physical grounds.
Ah, all right I just had in my mind that it would come out to be something the come be simplified a bit more. Thanks.
Related Threads on Expectation Value of Momentum
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
