Understanding Expectation Value in Quantum Mechanics: A Closer Look
In summary, the concept of expectation value is the average of all possible outcomes of an experiment. Mathematically, this is represented as the sum of xk times the probability density P, divided by the sum of the probability density. The expectation value can also be expressed as the integral of the position times the probability density. However, when considering the expectation value of the energy operator, the two equations do not give the same results. This is because the energy operator is only applicable in the position representation.
GAGS
55
We all know the concept of expectation value,it is the average of all possible outcomes of an experiment. Mathematically average of x is written as (Σnkxk / Σnk ). Quantum-mechanically nk is represented by probability density(P), where P = ∫Ψ*Ψ d3r,
then <r> = ∫ r P(r) d3r -----------(1)
or <r> = ∫ Ψ*(r) r Ψ(r) d3r--------(2) (normalisation condition)
but when we consider expectation value of Energy operator (= ih∂/∂t) the two equations ,to me, not give the same results. Can anybody solve what’s that dilemma and where I am wrong
The expectation of an operator H is defined as <[itex]\Psi[/itex]|H|[itex]\Psi[/itex]>. The form (1) above holds only under special circumstances.
Note: H = ih∂/∂t is the energy operator only when expressed in the position representation.
Pete
Thank you for your explanation of expectation value in quantum mechanics. I understand the importance of understanding this concept in order to accurately analyze and interpret experimental results.
In regards to your question about the discrepancy between equations (1) and (2) when considering the expectation value of the energy operator, it is important to note that equation (1) is the general expression for expectation value in quantum mechanics, while equation (2) is specific to the position operator.
The expectation value of the energy operator is given by the equation <E> = ∫Ψ* (ih∂/∂t) Ψ d3r. This equation takes into account the time-dependence of the wavefunction, which is not present in equation (2). This is why the two equations do not give the same results.
Additionally, the energy operator is a Hermitian operator, meaning that its expectation value will always be a real number. This may also contribute to the difference in results between the two equations.
I hope this helps clarify the dilemma you were experiencing. It is important to carefully consider the specific operators and equations being used when calculating expectation values in quantum mechanics.
What is the definition of Expectation Value?
The expectation value is a concept used in probability and statistics to describe the average or expected outcome of a random variable. It is calculated by multiplying each possible outcome by its probability and summing them together.
How is Expectation Value different from Mean?
While the expectation value and mean are often used interchangeably, there is a subtle difference between them. The mean refers to the average of a set of values, while the expectation value is the average outcome of a random variable, taking into account its probabilities.
What is the significance of Expectation Value in Quantum Mechanics?
In quantum mechanics, the expectation value is used to predict the outcome of a measurement of a quantum system. It represents the most probable outcome of the measurement and is calculated using the wave function of the system.
Can the Expectation Value be negative?
Yes, the expectation value can be negative if the probabilities of the outcomes are also negative. This can occur in situations where there is a higher chance of a negative outcome than a positive one.
How is the Expectation Value calculated in practice?
In practice, the expectation value is calculated by taking the average of a large number of measurements or by using mathematical equations and models to predict the outcome. It is an important tool for making predictions and analyzing data in various scientific fields.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
