Finding Heat Capacity of Metal: Experiments & Ideas
In summary, the author is looking for a third experiment to find the specific heat capacity of a metal block. Two experiments have been proposed, but the author is not sure how the third experiment would work.
gem0688
37
:confused: Hey ya, I need to design 3 different experiments to find the specific heat capacity of a metal block. I have got 2 but am just stuck for a third. The two i have are:
Method of mixtures
Heat up metal block in a water math, transfer to a cold water bath and observe the temperature rise.
Electrical method
Heat up metal block with a heating rod inserted in, measure voltage, current and temperature every 30 seconds.
I have been trying to find another method, and have found a mechanical method (use a crank to raise a load) but am not sure how that works.
Anyone have any ideas of a possible experiment or how the crank one works?
Thanx :smile: :confused: o:)
You could heat up the bock using a fuel of known chemical composition. Weigh the fuel before and after heating, this will allow you to calculate the energy released during combustion. Measure the temperature of the block before and after heating.
Regards,
~Hoot
Ok so then i can see how much energy has been used to raise the temperature of a certain mass by my change in temperature. ok think i understand that one, thanx, any ideas on how the crank might work too? :confused:
The apparatus is called Callendar's drum (a hollow cylindrical metal drum in which a known quantity of water is inserted or a solid cylindrical metal drum). A band is wrapped around the drum which is rotated at a constant rate (count the amount of revolutions). From one end of the band masses are hung and the other end is kept under tension by a spring balance. The work done by the friction (difference between the tension and weight times the circumference of the drum times the revolutions) on the drum heats it up (measure the temperature increase for the work done by the frictional force). This enables one to calculate the shc of the drum material.
Ok, thanx. So this would not be a suitable method for a solid metal block then because it has to be a hollow cylindrical metal drum. Have you got any ideas about a solid cylindrical metal?
No, it can be done with a solid drum too.
ohh ok. So the experiment would be as you described it but without the water, instead just the solid drum.
Yes. The heat transferred to it is a result of the work done by the friction of the band wrapped around it. Determining the mass and resulting temperature rise enables one to calculate the shc of the material.
Do you have any ideas of any other posiible experiments?
So, in the crank experiment, the heat is caused by the work done to overcome the friction, so that is the heat supplied. Then because i know the mass of my metal and i can measure the temperature rise i can put it into the SHC equation:
SHC = heat transferred
Mass x Temperature rise
to get my SHC. Yup?
Think i understand that one now!
thnx :smile: :approve:
1. What is heat capacity?
Heat capacity is the amount of heat required to raise the temperature of a substance by 1 degree Celsius.
2. How is heat capacity measured?
Heat capacity can be measured by conducting experiments in which a known amount of heat is added to a substance and the resulting change in temperature is measured.
3. Why is it important to find the heat capacity of metal?
Knowing the heat capacity of metal is important because it can help in understanding how the metal will behave in different temperature environments and can also aid in designing efficient heating and cooling systems.
4. What are some common experiments for finding the heat capacity of metal?
Some common experiments for finding the heat capacity of metal include the method of mixtures, where the metal is heated to a known temperature and then added to a substance with a known heat capacity, and the electrical method, where a known amount of electrical energy is used to heat the metal and the resulting change in temperature is measured.
5. Are there any other factors that can affect the heat capacity of metal?
Yes, other factors such as the purity and composition of the metal, as well as any impurities present, can also affect its heat capacity. Additionally, the temperature range at which the heat capacity is measured can also impact the results.
  • Thermodynamics
