Exponential Distribution
  • Thread starter Mentallic
Mentallic
3,798
94
If we have the exponential distribution [tex]f_X(x)=\frac{1}{2}e^{-x/2}[/tex] then show that the cumulative distribution function of [tex]Y=\sqrt{X}[/tex] is given by [tex]F_Y(y)=1-e^{-y^2/2}[/tex]
[tex]F_Y(y)=f_X(x)\cdot\left| \frac{dx}{dy}\right|[/tex]
[tex]F_Y(y)=f_X(h^{-1}(y))\cdot\left| \frac{d(h^{-1}(y))}{dy}\right|[/tex]
[tex]Y=\sqrt{X}=h(x)[/tex]
[tex]\therefore h^{-1}(y)=y^2[/tex]
[tex]\frac{d(h^{-1}(y))}{dy}=2y[/tex]
[tex]f_X(h^{-1}(y))=\frac{1}{2}e^{-y^2/2}[/tex]
[itex]\therefore[/itex] after plugging these values into the formula in the relevant equations,
[tex]F_Y(y)=y\cdot e^{-y^2/2}[/tex]
Which is not what I was meant to show. I only had one example in my text book to go off of and I (from what I can tell) think I applied it correctly to my question, but clearly I haven't. Can someone please guide me in the right direction, and also if you can see anything in my steps that need to be scrutinized, don't be afraid to speak out.
Answers and Replies
You used an incorrect equation.
[itex]f_Y(y)=f_X(x)\cdot\left| \frac{dx}{dy}\right|[/itex].
What you found was the PDF not the CDF. You have to integrate.
Mentallic
3,798
94
Oh, cheers :biggrin:
Ray Vickson
Dearly Missed
10,706
1,722
Rather than plugging in formulas, I think it is better to proceed from first principles: [tex] P\{Y \leq y\} = P\{ \sqrt{X} \leq y \} = P\{ X \leq y^2 \} = \left. (1 - e^{-x/2})\right|_{x=y^2}. [/tex]
RGV
Mentallic
3,798
94
Doesn't the jump between these two steps defeat the purpose? I believe I'm meant to use the integral to show that.
Now, if I were to calculate P(Y<x) for example, wouldn't I need to integrate again? Which means that I'd need to find a numerical solution.
edit: Never mind, I wouldn't integrate again.
Ray Vickson
Dearly Missed
10,706
1,722
There is no such a thing as "meant to" (unless stated explicitly). Your are "meant to" do anything that is correct and that you feel comfortable doing; aside from that, there are no rules. If you prefer to use the formulas you wrote before, go ahead and do that, but there are other ways to proceed, too, and I showed you one of them (which happens to be the one I personally prefer).
RGV
Mentallic
3,798
94
RGV
Sorry, I guess I wasn't clear. What I was trying to say was, didn't you arrive at that answer by integrating? It seems that in between those two steps there was some integration involved. And yes, I've also done essentially what you have there.
Ray Vickson
Dearly Missed
10,706
1,722
It all depends on where you start. I am so used to the exponential CDF, F(x) = 1 - exp(-ax), that I write it down almost without thinking. Of course it was obtained way in the past by integration. Still, doing its integral is a little bit easier than integrating your f_Y(y).
RGV
Related Threads on Exponential Distribution
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
