Exponential map
  • Thread starter geoduck
geoduck
257
I'm having trouble understanding the exponential map for nonlinear vector fields.
If dσ/dt=X(σ)
for vector field X, then how does one interpret the solution:
σ(t)=exp[tX]σ(0) ?
If X is nonlinear, then X is not a matrix, so this expression wouldn't make sense.
If X is a matrix that maps:
X: point on manifold → vector (direction of flow) on manifold
then this expression makes sense.
Answers and Replies
quasar987
what's a nonlinear vector field? Plz define it.
geoduck
257
A linear vector field has the property that X(p1+p2)=X(p1) +X(p2), where p are points in your space. In 2 dim, they look like
X=(ax+by,cx+dy)
for constant a b c d.
A nonlinear field is
X=X(f(x,y),g(x,y))
quasar987
I think I know what is confusing you. You are basically asking "what does exp(tX) means when X is not a matrix ?!?". The answer is that in the context of flows, exp(tX) is just a notation for the solution of the ODE dσ/dt=X(σ). The reason for this strange notation is tha the stolution of this equation has the "exponential property": exp([s+t]X) = exp(sX)exp(tX).
geoduck
257
I was looking at some online notes, and they explained it in terms of linear vector fields so that it's not just notationally true, but literally true (there are a few typos, but the first two pages has it):
http://mysite.science.uottawa.ca/rossmann//Lie_book_files/Section 1-1.pdf
But in textbooks the exponential map is applied to any flow, not just linear ones.
So it seems you can define an exponential map for a lot of things...things that obey the additive group for example, or just a Lie group in general if you expand the "exponential property" via Baker-Campbell Hausdorff.
quasar987
In Lie groups, the exponential map appears also just as a flow, but we are only looking at exp(tX) for X a so-called "left-invariant" vector fields on G.
There is also a notion of exponential map in riemannian geometry which is similar in a way to the exponential map in Lie group theory but is not the flow of any vector field on M.
Suggested for: Exponential map
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
