1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Exponential to Logarithm
  1. Jun 18, 2007 #1
    VietDao29
    Hi,
    Okay, I just went over some old stuff this week to prepare for the next vast vast, upcoming test.
    I came across a Logarithmic Equation book, well, it's more than 300 pages long, it covers most things from Exponential to Logarithm. :surprised :woot: I have read about 1/4 of it, and I was stuck. :cry:
    There are some problems there, but it's like they give out 10 problems, and they only guide you to solve 2, or 3 of them. And the others, you have to do it on your own. >"<
    The chapter I was reading was about Using the Mean Value Theorem to Equations. Here's a brief (well, not-so-short, to put it exactly) summary of this chapter, in case anyone needs it :smile:. The problems I stuck on are at the end of the post.
    Sumary:
    Firstly, the book states the Lagrange's theorem:
    If f(x) is continuous on the interval [a; b], and f(x) is differentiable on [a; b], then there will always exist a c on (a; b) such that:
    [tex]f'(c) = \frac{f(b) - f(a)}{b - a}[/tex]​
    Then, it says that there are 2 kinds of problems:
    The first type:: Prove that the equation f(x) = 0 has root(s):
    First step is to find F(x), the anti-derivative of f(x), differentiable, and continuous on the interval [a; b], such that: F(b) - F(a) = 0.
    Then, there exists an x0 on (a; b), such that:
    [tex]F'(x_0) = \frac{F(b) - F(a)}{b - a} = 0 \Rightarrow f(x_0) = 0[/tex]
    So that means the equation f(x) = 0 has at least one root on (a; b).
    Example:
    Given a/3 + b/2 + c = 0, prove that
    a22x + b2x + c = 0 always has solution.
    Solution:
    Let t = 2x ~~> t > 0
    Consider F(t) = (a/3)t3 + (b/2)t2 + ct. It's differentiable, and continuous on [tex](0 ; \infty )[/tex]
    F'(t) = at2 + bt + c = a22x + b2x + c
    F(1) - F(0) = (a/3 + b/2 + c) - 0 = a/3 + b/2 + c = 0
    So, the equation F'(t) = 0 (i.e at2 + bt + c = 0) always has solution on he interval (0; 1), hence, the former equation also has solution (Q.E.D)
    The second type:: Solve an equation:
    First step is to assume that [tex]\alpha[/tex] is the solution to the equation.
    Re-arrange the equation into the form f(a) = f(b), from there, find the appropriate f(t), continuous, and differentiable on [a; b].
    Then, by using the Mean Value Theorem, we'll solve for [tex]\alpha[/tex].
    And the last step is to check the solution.
    Example:
    Solve:
    6x + 2x = 5x + 3x
    Solution:
    Re-arrange the equation to give:
    6x - 5x = 3x - 2x
    Assume that [tex]\alpha[/tex] is the solution to the above equation. So, we have:
    [tex]6 ^ \alpha - 5 ^ \alpha = 3 ^ \alpha - 2 ^ \alpha[/tex] (1)
    Let [tex]f(t) = (t + 1) ^ \alpha - t ^ \alpha, \ \ \ \ \ t > 0[/tex], from (1), we have: f(5) = f(2)
    By the Mean Value Theorem, there exists a c on the interval (2; 5), such that:
    [tex]f'(c) = \frac{f(5) - f(2)}{5 - 2} = 0 \Rightarrow \alpha (c + 1) ^ {\alpha - 1} - \alpha c ^ {\alpha - 1} = 0[/tex]
    [tex]\Rightarrow \alpha \left[ (c + 1) ^ {\alpha - 1} - c ^ {\alpha - 1} \right] = 0 \Rightarrow \left[ \begin{array}{l} \alpha = 0 \\ \alpha = 1 \end{array} \right.[/tex]
    So, the two solution to the equation is x = 0, or x = 1. After testing the two solution, we see that they are all valid.
    Example:
    Solve for x:
    3cos(x) - 2cos(x) = cos(x)
    Solution:
    3cos(x) -3 cos(x) = 2cos(x) - 2cos(x)
    Assume that [tex]\alpha[/tex] is the solution to the equation, we have:
    [tex]3 ^ {\cos (\alpha) } - 3 \cos \alpha = 2 ^ {\cos (\alpha)} - 2 \cos \alpha[/tex] (2)
    Let [tex]f(t) = t ^ {\cos \alpha} - t \cos \alpha[/tex]
    From (2), we have: f(3) = f(2)
    Applying the Mean Value Theorem, we have:
    There exists a c on (2, 3), such that:
    [tex]f'(c) = 0 \Rightarrow \left[c ^ {\cos \alpha} - 1 \right] \cos \alpha = 0 \Rightarrow \left[ \begin{array}{l} \cos \alpha = 0 \\ \cos \alpha = 1 \end{array} \right.[/tex]
    [tex]\Rightarrow \left[ \begin{array}{l} \alpha = \frac{\pi}{2} + k \pi \\ \alpha = 2 k' \pi \end{array} \right. , \ \ \ \ \ k, k' \in \mathbb{Z}[/tex]
    Testing the two solutions above, we see that they are all valid, so there are 2 solution to the equation:
    [tex]\Rightarrow \left[ \begin{array}{l} x = \frac{\pi}{2} + k \pi \\ x = 2 k' \pi \end{array} \right. , \ \ \ \ \ k, k' \in \mathbb{Z}[/tex]
    Pfff, so, well, it's the summary.
    And there are 2 problems I stuck on:
    Problem 1:
    Given a, b, c in Z+, i.e {1, 2, 3, 4, ...}, and a2 + b2 = c2
    Prove that:
    ax + bx = cx only has one solution.
    Attempt:
    a2 + b2 = c2 means that c > a, and c . b.
    Divide both sides by cx, to get:
    (a/c)x + (b/c)x = 1
    The LHS is a decreasing function, hence, if there is root to the equation, it cannot be more than 1.
    From the given condition, one can see that x = 2 is the only solution. :)
    It seems correct. Except that I haven't used the fact that a, b, and c are in Z+, my solution is valid for, a, b, and c in R+. So, I think I must be missing something here. :frown:
    Is it me, or the book mistype the Z+ thingy? Or does the book expect me to solve it in another way?
    Problem 2:
    Find all solution to the equation:
    (1 + cos x)(2 + 4cos(x)) = 3 (4cos x)
    Well, I have absolutely no idea how to start it. :cry: :cry: Some body please give me a start.
    Thanks very much. :)
  3. Jun 18, 2007 #2
    Hey,
    Just looking at it before I tried anything, I see that cos x=1 is a solution.
    So anywhere cos(x)=0 is a solution.
    CC
  4. Jun 18, 2007 #3
    VietDao29
    Yeah, even cos(x) = 1/2 is a solution, I got it when using Trial-and-Error method frantically. But, well, I cannot factor this expression, or re-arrange it to any desirable form. :frown:
  5. Jun 18, 2007 #4
    Allright,
    So I multiplied it out and I got:(letting cos(x)=a for easiness)
    [tex]2+2a+a4^a+4^a=3(4^a)[/tex]
    Then I used the following:
    2=4-2
    2a=4a-2a
    [tex]2(4^a)=4(4^a)-2(2^a)[/tex]
    [tex]a4^a=2a4^a-a4^a[/tex]
    which gives:
    [tex]4+4a+2a4^a-4(4^a)=2+2a+a4^a-2(2^a)[/tex]
    So I think that works.
    CC
  6. Jun 19, 2007 #5
    VietDao29
    Yeah, yeah, it works. :approve: Thanks a lot, mate.
    Btw, I have one question. How can you split it into that form, is there anything that suggest you to do that, or you get it by chance? I don't think I can think of that re-arrangement though. :redface:
  7. Jun 19, 2007 #6
    I just looked at the form of the terms and realizing that I needed the same types of terms on both sides of the equation, just divided each one up. After I multiplied it out and cancelled the one [tex]4^a[/tex] term, I saw that the 4's and 2's for the coefficients would probably work. With just a little tinkering the thing fell out.
    I didn't solve it past that. What did you get for solutions? Was the cos(x)=1 and cos(x)=1/2 all there were?
    CC
