Can we use Taylor expansions to find the series representation of sin(x^(3/2))?
  • Thread starter Undoubtedly0
  • Tags
    Taylor
In summary, the conversation discusses the Taylor series of sin(x^(3/2)) and the question of why it does not follow the chain rule. It is mentioned that this series is not a power series because it contains terms like x^(3/2), and that sin(x^(3/2)) is not twice differentiable at x=0, so it does not have a Taylor series representation at 0. It is explained that in general, substituting g(x) into the power series representation of f is possible as long as g(x) remains within the interval of convergence, but it will not necessarily result in a power series.
Undoubtedly0
98
It is well-known that the Taylor series of [itex]\sin x[/itex] about [itex]x=0[/itex] is [tex]\sin x = \sum_{n=0}^{\infty} \frac{(-1)^n}{(2n+1)!}x^{2n+1}[/tex]
By extension, one might presume that the Taylor series of [itex]\sin x^{3/2}[/itex] about [itex]x=0[/itex] is
[tex]\sin x^{3/2} = \sum_{n=0}^{\infty} \frac{(-1)^n}{(2n+1)!}x^{\frac{3}{2}(2n+1)}[/tex]
This is indeed the case, but why? Finding the Taylor series of [itex]\sin x^{3/2}[/itex] from the definition does not give a convergent series. In general, my question is, if
[tex] f(x) = \sum_{n=0}^{\infty} \frac{f^{(n)}(0)}{n!}x^n [/tex]
why is
[tex] f(g(x)) = \sum_{n=0}^{\infty} \frac{f^{(n)}(0)}{n!}g(x)^n [/tex]
It seems like this last expression would involve chain differentiation, but does not. Thanks all - I hope I have explained my question properly.
Why do you think your last expression is not in conformity with the chain rule??
Your series is a valid absolutely convergent series representation of sin(x^(3/2)). However, it is not a power series because it has terms like x^(3/2). Therefore, it cannot be a Taylor series.
The fact is that sin(x^3/2) is not twice differentiable at x=0, so it does not have a Taylor series representation at 0.
In general, you can substitute g(x) into the power series representation of f as long as g(x) remains inside the interval of convergence of the power series. You will then have a series representation for f(g(x)). However, the resulting formula won't necessarily be a power series.
1. What is the purpose of extending Taylor expansions?
The purpose of extending Taylor expansions is to approximate a more complex function using a simpler one. This can make calculations and analysis easier and more efficient.
2. How do you extend a Taylor expansion?
To extend a Taylor expansion, you can add more terms to the original expansion. These terms can be calculated using the derivatives of the function at the point of expansion.
3. What is the difference between a Taylor series and a Taylor expansion?
A Taylor series is an infinite sum of terms that approximates a function, while a Taylor expansion is a truncated version of the series that only includes a finite number of terms.
4. What is the significance of the remainder term in a Taylor expansion?
The remainder term in a Taylor expansion represents the difference between the actual value of the function and its approximation. It helps to quantify the accuracy of the approximation and determine how many terms are needed for a desired level of precision.
5. When should you use a Taylor expansion instead of the original function?
A Taylor expansion should be used when the original function is too complex to work with or when only a specific range of values is needed. It can also be used to approximate functions in cases where the original function is not known.
