Solving for Speed of Extreme Skier Descending Mountain
  • Thread starter rcmango
  • Tags
    Speed
In summary, an extreme skier starting from rest coasts down a mountain at a 25.0° angle with the horizontal, with a coefficient of kinetic friction of 0.200. After traveling 12.3 m, she reaches the edge of a cliff and continues without slowing down. She lands downhill at a point 3.70 m below the edge. To determine her velocity before landing, the friction work must be subtracted from the change in gravitational potential energy, and the resulting kinetic energy can then be used to calculate the velocity.
rcmango
234
An extreme skier, starting from rest, coasts down a mountain that makes an angle 25.0° with the horizontal. The coefficient of kinetic friction between her skis and the snow is 0.200. She coasts for a distance of 12.3 m before coming to the edge of a cliff. Without slowing down, she skis off the cliff and lands downhill at a point whose vertical distance is 3.70 m below the edge. How fast is she going just before she lands?
W = KEf -KE0
(1/2mv^2 - 1/2m* v^20)
Conservation of energy does not apply when there is friction unless you include the heat generated by the friction.
To solve this problem you need to use the friction.
It's a 3 stage problem and only the last can be solved by conservation of energy: 1) an acceleration down ramp 2) a deceleration along the horizontal from bottom of ramp to edge of cliff and 3) a vertical acceleration while horizontal velocity is unchanged.
Well from the distance traveled and the angle, one can determine the change in elevation of the skier on the mountain. If the snow was frictionless, then this change in elevation (change in gravitational potential energy, GPE) would be transformed into kinetic energy (conservation of energy). However, there is a dissipative force - friction - which does work against the skier, so this work has to be subtracted from the GPE to find the KE at the point where the skier leaves the cliff. Knowing the KE, one determines the velocity, which is the initial velocity for the second part of the problem where the skier is in free fall for 3.7 m.
Note that since the skier's velocity is at 25° with respect to horizontal, there is both a horizontal and vertical component to the velocity.
What is the speed of an extreme skier descending a mountain?
The speed of an extreme skier descending a mountain can vary depending on a variety of factors such as the steepness of the slope, snow conditions, and the skill level of the skier. However, on average, an extreme skier can reach speeds of up to 60 miles per hour.
What is the formula for calculating speed?
The formula for calculating speed is speed = distance/time. This means that in order to determine the speed of an extreme skier descending a mountain, we need to know the distance traveled and the time it took for the skier to cover that distance.
How is the speed of an extreme skier measured?
The speed of an extreme skier can be measured using various methods such as radar guns, GPS devices, or by timing the skier's descent using a stopwatch. These methods provide accurate measurements of the skier's speed.
Can the speed of an extreme skier be controlled?
Yes, the speed of an extreme skier can be controlled to some extent by adjusting their body position, the direction of their skis, and using techniques such as carving and braking. However, factors such as the slope and snow conditions can also affect the skier's speed.
What safety precautions should extreme skiers take when descending a mountain at high speeds?
Extreme skiers should always wear proper safety gear, including a helmet, to protect themselves in case of a fall. They should also be aware of their surroundings and avoid areas with potential hazards. Additionally, it is important to regularly check and maintain equipment, and to only attempt high-speed descents if the skier has the necessary skills and experience.
