Distance of Hurricane from Grand Bahama Island: 104 km
In summary, the eye of a hurricane passes over Grand Bahama Island at a speed of 37.0 km/h and a direction of 60.0° north of west. Three hours later, it shifts due north at a speed of 27.0 km/h. Using the pythagorean theorem, the hurricane is 104 km away from Grand Bahama Island after a total of 4.50 hours.
mortho
100
The eye of a hurricane passes over Grand Bahama Island. It is moving in a direction 60.0° north of west with a speed of v1 = 37.0 km/h. Exactly three hours later, the course of the hurricane shifts due north, and its speed slows to v2 = 27.0 km/h, as shown in Figure 3-30. How far from Grand Bahama, in kilometers, is the hurricane 4.50 h after it passes over the island?
sine, cosine
i ended up getting 104 km using tangent to find the angle then using the angle and opposite to find adgacent which i got 104. the sides were 111km and 40.5 km after multiplying with the velocity conversion.
I don't think you need to find the angle of anything. I agree that the total distances traveled are 111 and 40.5. Keep in mind that these have a certain direction. The real problem is the first one because it has north and west components. If you can figure out what those are, then you can add the second displacement to the north component. With the total north and west displacements, you can use the pythagorean theorem to find the total distance away.
Your solution using trigonometry to find the distance of the hurricane from Grand Bahama Island is correct. However, it would be beneficial to also consider the direction and speed of the hurricane in your solution. The direction of the hurricane shifted from 60.0° north of west to due north, which means the angle of movement also changed. This could affect the final distance calculation. Additionally, you could also consider using the Pythagorean theorem to find the total distance traveled by the hurricane in the given time frame. Overall, your approach is valid and the resulting distance of 104 km is accurate.
1. What does "Distance of Hurricane from Grand Bahama Island: 104 km" mean?
This refers to the distance between the center of the hurricane and Grand Bahama Island, measured in kilometers.
2. How is the distance of a hurricane from an island determined?
The distance is typically determined using satellite imagery and measuring the distance between the center of the hurricane and the island.
3. Is 104 km considered a safe distance from the hurricane?
It depends on the strength and size of the hurricane. Generally, it is considered a safe distance, but it is always best to follow the guidance and warnings from local authorities.
4. Can the distance of a hurricane from an island change?
Yes, the distance can change as the hurricane moves and its path may shift. It is important to regularly check updates and evacuation notices from authorities.
5. Is the distance of a hurricane from an island an accurate predictor of its impact?
While the distance can give an indication of the potential impact, the size and strength of the hurricane, as well as other factors such as storm surge and wind direction, also play a significant role in determining its impact on an island.
