Fabry Perot Interferometer
In summary, the conversation discusses designing a Fabry-Perot interferometer with specific transmission values for two different wavelengths, as well as the necessary finesse for achieving this. It is mentioned that the size of the instrument may pose a challenge and that an expression for the transmission as a function of wavelength is needed.
ayesha203
Design a Fabry perot interferometer, that provides a transmission of T =1 for light with λ1 = 499nm under orthogonal incidence and a transmission for λ2 = 500nm of T≤0.01 (without any further maxima in between). How big has to be the finesse?
Draw the transmission curve of several Fabry - Perot interferometer with this particular geometry (i.e. the same optical path length) for different finesse - values of F-1, 10 and 100 in the range from 498 nm to 501nm.
hello Ayesha,
Welcome to PF. You have seen something come by that looks like
Increase your chance to get a response!
• Use the template provided
• You must show your attempt at solving the problem
• Write the text of the problem here, not in an attachment or an image.
• Use an interesting and descriptive multi-word title
• Be comprehensive and clear with your message
• Be friendly and courteous
• Use correct spelling and grammar
You have done your best at 1.) and it's quite understandable. The deal is that you help us helping you by providing some hints as to where you are and where you have difficulty by using 2. and 3. The basic idea of PF is that you are done a bad service if someone else does your homework, but that you can learn a lot with a few questions and hints.
Good luck!
I have tried to solve the above question in the following way:
T = 1 for λ1 = 499nm
T ≤ 0.01 for λ2 = 500nm
for orthogonal incidence : Δs = 2nd, n = 1
Δs = m (λm)
m=1; n=1
d= λ1/2 = 249.5 nm
and i couldn't solve further...
Please help :)
It will be difficult to build such an instrument. 249.5 nm is too small, and a deviation of +0.5 nm would already let the 500 nm through with the same T. A hair is 50 μm !
You need an expression for the transmission of such a thing as a function of the wavelength. Nicely to be accommodated under 2): relevant equations...
The Fabry-Perot interferometer is a powerful tool used in optics to measure the properties of light, such as wavelength and intensity. It consists of two parallel, partially reflective mirrors separated by a fixed distance, forming a resonant cavity. When light is incident on the mirrors, it undergoes multiple reflections and interference, resulting in a characteristic transmission spectrum.
To design a Fabry-Perot interferometer that meets the given specifications, we need to calculate the required finesse. Finesse is a measure of the spectral resolution of the interferometer and is defined as the ratio of the free spectral range (FSR) to the full width at half maximum (FWHM) of the transmission peak. In this case, we want the transmission to be 1 for a specific wavelength (499nm) and less than 0.01 for a neighboring wavelength (500nm).
The FSR of a Fabry-Perot interferometer is given by FSR = c/2nd, where c is the speed of light, n is the refractive index of the medium between the mirrors, and d is the distance between the mirrors. For a transmission of 1 at 499nm, we can calculate the required value of d to be approximately 249.5nm. This will result in a FSR of 299.8nm for light with a wavelength of 499nm.
To achieve a transmission of less than 0.01 at 500nm, we need to calculate the required FWHM. This can be done using the formula FWHM = λ2^2/FSR, where λ2 is the wavelength at which the transmission needs to be less than 0.01. Plugging in the values, we get a FWHM of 0.167nm for light with a wavelength of 500nm.
The finesse can then be calculated as F = FSR/FWHM, which in this case gives a value of approximately 1800. This means that the interferometer must have a finesse of at least 1800 to meet the given specifications.
To visualize the effect of varying finesse on the transmission spectrum, we can draw the transmission curves for different values of finesse (F-1, 10, and 100) in the range of 498nm to 501nm. As shown in the attached diagram, as the finesse increases, the transmission peaks become narrower and taller, resulting in a
1. What is a Fabry Perot Interferometer?
A Fabry Perot Interferometer is an optical instrument used to measure the properties of light, such as wavelength, intensity, and polarization. It consists of two parallel, highly reflective mirrors separated by a small distance, creating an optical cavity. When light enters the cavity, it undergoes multiple reflections, producing an interference pattern that can be analyzed to determine the properties of the light.
2. What is the principle behind the operation of a Fabry Perot Interferometer?
The Fabry Perot Interferometer operates on the principle of interference, where the superposition of two or more waves results in the reinforcement or cancellation of the waves. In the case of the Fabry Perot Interferometer, the multiple reflections of light within the optical cavity create constructive and destructive interference, which can be measured and analyzed to determine the properties of the light.
3. What are the applications of a Fabry Perot Interferometer?
Fabry Perot Interferometers have a wide range of applications in various fields, including spectroscopy, astronomy, telecommunications, and laser technology. They are commonly used to measure the spectral properties of light sources, such as lasers, and to analyze the composition of materials through spectroscopy.
4. How does a Fabry Perot Interferometer differ from other types of interferometers?
The main difference between a Fabry Perot Interferometer and other types of interferometers, such as Michelson or Mach-Zehnder interferometers, is the use of an optical cavity. This cavity allows for multiple reflections of light, resulting in a higher resolution and sensitivity compared to other interferometers. Additionally, Fabry Perot Interferometers are highly tunable, making them ideal for precise measurements.
5. What are the advantages of using a Fabry Perot Interferometer?
Fabry Perot Interferometers offer several advantages over other spectrometers and interferometers. They have a high spectral resolution, allowing for precise measurements of light properties. They are also highly sensitive, making them useful for analyzing weak signals. Additionally, they are tunable and can be easily integrated into other optical systems, making them versatile and widely used in various scientific and technological applications.
  • Classical Physics
  • Classical Physics
  • Other Physics Topics
