Fabry-Perot Laser Homework: Explaining Steady State Oscillation
  • Thread starter zak8000
  • Tags
    Laser
This is supported by the steady state condition for laser oscillation and the calculated values for the round-trip gain and loss.
zak8000
74
Consider a Fabry-Perot laser, length 0.1m, with an unsaturated gain coefficient, [itex]\gammao[/itex]=1m-1
one of the mirrors of the Fabry-Perot cavity is perfectly reflecting, the other reflects 95% of the light and transmits 5%. wit the aid of a brief calculation explain why steady state laser oscillation is expected?
i had no idea on how to approach this question so i did some research and i found this book kind of helpful under this link:
http://books.google.co.nz/books?id=...rip gain greater than round trip loss&f=false
after reading a chapter in the book the steady state condition is R1R2exp(2aL-j2wL/c)=1
since i am not given any frequency value i only solved the condition for the round trip amplitude coefficent and the way i calculated it was R1R2exp(2aL)=1 --->0.95exp(2*1*0.1)=1.15
please help i cam confused on how to prove this
To approach this problem, we can use the concept of round-trip gain and loss in a Fabry-Perot laser. The round-trip gain is the total gain experienced by the light as it travels back and forth between the two mirrors of the cavity, while the round-trip loss is the total loss experienced by the light.
In this case, the round-trip gain is given by the unsaturated gain coefficient, \gammao=1m-1, multiplied by the length of the cavity, which is 0.1m. This gives us a round-trip gain of 0.1m-1.
The round-trip loss is equal to the product of the reflectivities of the two mirrors, which are 100% and 95% respectively. This gives us a round-trip loss of 0.95*0.05 = 0.0475.
To have steady state laser oscillation, the round-trip gain must be greater than the round-trip loss. In this case, 0.1m-1 > 0.0475, which means that the gain is indeed greater than the loss and steady state laser oscillation is expected.
To prove this mathematically, we can use the steady state condition for laser oscillation: R1R2exp(2aL-j2wL/c)=1. Since we are not given a specific frequency, we can ignore the term j2wL/c and solve for the round-trip amplitude coefficient, which is the product of the reflectivities of the two mirrors. This gives us the equation R1R2exp(2aL)=1.
Substituting the values we have calculated for the round-trip gain and loss, we get R1R2exp(2*0.1m-1)=1.15. This value is greater than 1, which means that the gain is indeed greater than the loss and steady state laser oscillation is expected.
In conclusion, the Fabry-Perot laser described in the problem has a round-trip gain that is greater than the round-trip loss, which means that steady state laser oscillation is expected.
1. What is a Fabry-Perot laser?
A Fabry-Perot laser is a type of laser that uses an optical cavity made up of two parallel mirrors to create a resonant cavity where light can bounce back and forth, amplifying and producing a laser beam.
2. How does a Fabry-Perot laser produce steady state oscillation?
A Fabry-Perot laser produces steady state oscillation by using a gain medium, such as a semiconductor, to amplify light and create a population inversion. This results in a feedback mechanism between the mirrors in the cavity, causing the light to oscillate and produce a coherent laser beam.
3. What factors affect the steady state oscillation of a Fabry-Perot laser?
The steady state oscillation of a Fabry-Perot laser can be affected by several factors, including the reflectivity of the mirrors, the gain of the laser medium, the length of the cavity, and the external conditions such as temperature and current. These factors can impact the threshold for lasing and the quality of the output beam.
4. How does the length of the cavity affect the steady state oscillation of a Fabry-Perot laser?
The length of the cavity in a Fabry-Perot laser plays a crucial role in determining the quality of the steady state oscillation. If the cavity length is too short, the laser will operate in a single longitudinal mode, resulting in a narrow output beam. On the other hand, a longer cavity length can support multiple longitudinal modes, leading to a broader output spectrum.
5. Why is steady state oscillation important in Fabry-Perot lasers?
Steady state oscillation is important in Fabry-Perot lasers because it is necessary for producing a stable and coherent laser beam. It allows for precise control of the output beam characteristics, such as wavelength and intensity, making Fabry-Perot lasers useful in various applications, including telecommunications, spectroscopy, and laser printing.
