Homework Help: Factor a 3rd order polynomial
  1. Jul 4, 2012 #1
    What are the steps to factoring 3rd order polynomials like x^3+8x^2-21x+10?
    It's to find eigenvalues of a matrix in linear algebra, I completely forgot how to factor and it's killing me.
    2. Relevant equations
    3. The attempt at a solution
    None, unless its a polynomial that I can factor by grouping, I have no clue how to begin.
  3. Jul 4, 2012 #2
    Mute
    EDIT: Nevermind the below, that factor trick (the 'rational root test') doesn't work in this case. The discriminant is positive, but it turns out that all three roots are irrational.
    For a cubic polynomial with integer coefficients, which is what you have, I believe one of the roots is typically a factor of the constant term. So, try the factors of 10 and see if one of them is a root. Once you've figured out one of the roots, you can factor an (x-root) term out by polynomial division, leaving you with (x-root)*quadratic, and the quadratic you can factor with the quadratic formula.
  4. Jul 4, 2012 #3
    :( so the pq thing with synthetic and what-the-other-one's-name division?
    I dont know why i didnt think of it (but that sounds really tedious).
    Thanks for your help! :)
  5. Jul 4, 2012 #4
    Got it, so i happened to pick the only example in the book of a matrix with irrational eigenvalues. I'm still not so sure how to find the irrational roots of a 3rd order polynomial... i should change the name of this thread haha.
  6. Jul 4, 2012 #5
    eumyang
    There's always the cubic formula, but using it is a bit... tedious. :eek:
  7. Jul 7, 2012 #6
    To add to what "eumyang"" said, using the Cubic Formula to get an exact algebraic result is, indeed, a bit tedious.
    On the other hand, if you are fine with numerical results, there are several free online utilities available; some of them are listed at the bottom of that Wikipedia page.
    In addition, I refer you to an old post I made at the bottom of the following thread:
    https://www.physicsforums.com/showthread.php?t=580075&page=2
    A search of these forums would probably turn up much more information about factoring a cubic polynomial.
