Solving (b) (i) and (ii): Find Value of k and LCM of f(x) and f(x+k)
  • Thread starter kenny1999
  • Tags
    Value
In summary, the conversation discusses the factorization of f(x) and the search for a positive integer k where the HCF (GCF) of f(x) and f(x+k) is linear. The conversation also touches on finding the LCM of f(x) and f(x+k). The conversation does not provide a complete solution, but suggests using trial and error to find a suitable k.
kenny1999
235
given f(x) = x^3 - 6x^2 + 3x + 10
(a) Factorize f(x)
(b) if k is a positive integer such that HCF of f(x) and f(x+k) is linear.
(i) find value of k
(ii) find LCM of f(x) and f(x+k)
I have no problem with (a) and f(x) = (x+1) (x^2 - 7x + 10)
I have problem with (b) (i) and (ii), I only know that HCF is linear means that there is only one factor which is linear. And that's it. I know nothing further to solve the questipn
Do you need a complete factorization? If so, you are not finished. x2 - 7x + 10 is factorable.
i have factored f(x) into (x+1)(x-5)(x-2)
but no idea to go further
What are the factors of f(x+k)?
Using the factored form of f(x), find f(x+k).
I'm assuming that HCF=GCF (greatest common factor). You are looking for a positive k such that there is a linear common factor between f(x) and f(x+k). So one of the three factors of f(x) should also be a factor of f(x+k). I used trial and error to find such a k. Find a k so that when you plug into the factored form of f(x+k), one of its factors is also a factor of f(x).
(Hope I'm not giving away too much here.)
Yes, I think you are.
hi how about LCM?
kenny1999 said:
hi how about LCM?
Well, what about it? What work have you done on it so far?
What does it mean to solve for k and LCM in a function?
Solving for k and LCM in a function involves finding the value of k that makes the function have the least common multiple (LCM) with another function. This means finding the smallest value of k that results in the two functions having the same repeating pattern.
Why is it important to find the value of k and LCM in a function?
Finding the value of k and LCM in a function is important because it allows us to understand the relationship between two functions and how they behave. It can also help us simplify complex functions and make predictions about their behavior.
What are the steps involved in solving for k and LCM in a function?
The first step is to set the two functions equal to each other and solve for k. Then, substitute the value of k into one of the functions to find the LCM. Finally, simplify the LCM and the original functions to find the final values of k and LCM.
Can the value of k and LCM be negative?
Yes, the value of k and LCM can be negative. The value of k can be negative if it results in the two functions having the same repeating pattern, and the LCM can be negative if one of the original functions has a negative coefficient.
What are some real-life applications of solving for k and LCM in a function?
Solving for k and LCM in a function can be useful in fields such as engineering, physics, and economics. It can help in predicting periodic patterns in data, optimizing processes, and finding the most efficient solutions.
