Solve Quadratic Function with Factor Theorem
  • Thread starter Rowah
  • Tags
    Theorem
In summary, the quadratic function f(x) with integral coefficients that satisfies the given properties is f(x)=5(2x-3)(x-2), with the constant A=5 being necessary to satisfy the condition f(4) = 50.
Rowah
This is the problem:
A quadratic function f(x) with integral coefficients has the following properties: [tex]f(3/2)=0[/tex], (x-2) is a factor of f(x), and f(4) = 50. Determine f(x).
The answer in the back of the book is [tex]f(x)=5(2x-3)(x-2)[/tex]
I can easily understand the (2x-3) and (x-2), but I don't understand the "5", and "f(4) = 50".
f(4) = 50 means that the quadratic function evaluated at x = 4 has a value of 50. Your final solution must satisfy this condition as well as the others.
Hint, the "5" probably has something to do with that last criterion.
Hmm, when you sub f(4) = 50 in f(x)=(2x-3)(x-2)
You end up with 50=10
Am I on the right track towards implementing that "5" into my final equation?
Which tells you that f(x) is NOT (2x-3)(x-2)!
But you also know that 2x-3 and x- 2 are the only factors involving x.
What happens if you substitute x= 4 into f(x)= A(2x-3)(x-2) where A is a constant?
One word to describe HallsofIvy.. Brilliant!
You end up with A=5, thanks I understand it now :D
1. What is the Factor Theorem?
The Factor Theorem is a mathematical theorem that states that if a polynomial function f(x) has a factor (x-a), then the value of f(a) will be equal to zero.
2. How is the Factor Theorem used in solving problems?
The Factor Theorem is used to factorize polynomial expressions and solve equations. By finding the factors of a polynomial, we can determine the roots or solutions of the equation.
3. What are the key concepts to understand when using the Factor Theorem?
To use the Factor Theorem, it is important to understand the concept of factors, roots, and polynomial division. It is also helpful to be familiar with polynomial expressions and equations.
4. Can the Factor Theorem be applied to all polynomial equations?
No, the Factor Theorem can only be applied to polynomial equations with real coefficients. It also only applies to equations with one variable, such as x.
5. How can I check if a factor is correct using the Factor Theorem?
To check if a factor is correct, you can use the Remainder Theorem. If the remainder of polynomial division is zero, then the factor is correct. You can also plug in the value of the factor into the original equation to see if it results in a zero value.
