Quick Tips for Factoring Polynomials: Solving 7x^2-9X-6 Efficiently
In summary: the expression 6x^2+ 5xy- 6y^2= 6(x^2+ (5/6)xy- y^2) can be factored in two ways as (x+ 5/12)^2- (169/144)y^2 or (x+ 5/12)^2- ((13/12)y)^2.
tomtomtom1
160
hi all
I am stuyding how to factor equations such as :-
7x^2-9X-6
The problem i have is that it takes me too long to find 2 numbers whose sum is D and the same numbers whoes product is E.
Is there any way/tips/guide on how i can achieve this quickly?
tomtomtom1 said:
hi all
7x^2-9X-6
Have you studied how to solve quadratic equations? If so, you will know that the
quadratic equation ##7 x^2 - 9 x - 6 = 0## has roots ##r_1## and ##r_2##, and that means that the expression ##7 x^2 - 9 x - 6 ## factors as ## 7(x - r_1)(x-r_2)##. You can use the standard quadratic root formulas to find ##r_1## and ##r_2##.
BTW: the thing you are factoring is not an equation; it is an expression. An equation must have an '=' sign in it, and yours does not.
what about:-
X^2+xy-2y^2
6x^2+5xy-6y^2
What is the process of factoring such expressions?
tomtomtom1 said:
what about:-
X^2+xy-2y^2
6x^2+5xy-6y^2
Exactly the same as what I already explained.
[itex]x^2+ xy- 2y^2= 0[/itex]
[itex]x^2+ xy+ (1/4)y^2- (1/4)y^2- 2y^2= 0[/itex]
[itex](x+ (1/2)y)^2- (9/4)y^2= 0[/itex]
That's of the form "[itex]a^2- b^2= (a- b)(a+ b)[/itex]with a= x+ (1/2)y and b= (3/2)y
so [itex]x^2+ xy- 2y^2= (x+ (1/2)y+ (3/2)y)(x+ (1/2)y- (3/2)y)= (x+ 2y)(x- y)[/itex]
That's one way to do it- very "algorithmic". Another way, more "heuristic", is to note that the only way to factor [itex]x^2[/itex] (with integer coefficients) is (x)(x) while there are two ways to factor [itex]-2y^2[/itex] (again with integer coefficients) is (-2y)(y) or (2y)(-y). We try (-2y)(y): [itex](x- 2y)(x+ y)= x^2- 2xy+ xy- 2y^2= x^2- xy- 2y^2[/itex]. No, that's not what we want. So try (-y)(2y): [itex](x+ 2y)(x- y)= x^2+ 2xy- xy- 2y^2= x^2+ xy- 2y^2[/itex]. Yes, that's what we want.
[itex]6x^2+ 5xy- 6y^2= 6(x^2+ (5/6)xy- y^2)= 6(x^2+ (5/6)xy+ (25/144)y^2- (25/144)y^2- y^2)= 6((x+ 5/12)^2- (169/144)y^2)= 6((x+ 5/12)^2- ((13/12)y)^2)= 6(x+ 5/12+ 13/12)(x+ 5/12- 13/12))= 6(x+ 18/12)(x- 8/12)= 6(x+ 3/2)(x- 2/3)= (2x+ 3)(3x- 2)[/itex].
Or: 6=(3)(2) so we must have one of (3x- 3y)(2x+ 2y), (2x- 2y)(3x+ 3y), (3x- 2y)(2x+ 3y), or (2x- 3y)(3x+ 2y). Multiplying each of those out, we see that
[itex](3x- 3y)(2x+ 2y)= 6x^2+ 6xy- 6xy- 6y^2= 6x^2- 6y^2[/itex]
[itex](2x- 2y)(3x+ 3y)= 6x^2+ 6xy- 6xy- 6y^2= 6x^2- 6y^2[/itex]
[itex](3x- 2y)(2x+ 3y)= 6x^2+ 9xy- 4xy- 6y^2= 6x^2+ 5xy- 6y^2[/itex]
[itex](2x- 3y)(3x+ 2y)= 6x^2+ 4xy- 9xy- 6y^2= 6x^2- 5xy- 6y^3[/itex]
so that (3x- 2y)(2x+ 3y) is the correct factoring.
And we see that
What is factoring a polynomial?
Factoring a polynomial means finding its equivalent factors, which are expressions that can be multiplied together to produce the original polynomial.
Why is factoring a polynomial important?
Factoring a polynomial is important because it helps us solve equations, simplify expressions, and understand the behavior of the polynomial function.
What are the different methods for factoring a polynomial?
There are several methods for factoring a polynomial, including grouping, difference of squares, perfect square trinomials, and the quadratic formula.
How do I know when a polynomial is completely factored?
A polynomial is completely factored when none of the factors can be further simplified or factored into smaller expressions.
Can I factor all polynomials?
No, not all polynomials can be factored. Some polynomials, known as prime polynomials, have no factors other than 1 and themselves. Additionally, factoring can become increasingly complex for higher degree polynomials.
  • General Math
  • General Math
