Homework Help: Factoring Madness
  1. Feb 4, 2010 #1
    I need to find where these curves intersect:
    x+y = 2y^2
    y = x^3
    2. Relevant equations
    3. The attempt at a solution
    So I try to write both in terms of y, I get
    2y^2 - y = y^(1/3)
    I try to factor
    2y^2 - y - y^(1/3) = 0
    y(2y - 1 - y^(-2/3)) = 0 ??
    What do I do next?
  3. Feb 5, 2010 #2
    Mark44
    Staff: Mentor
    You're on the right track up to the step above, but that's not an equation that's easy to factor with that cube root.
    Instead, cube both sides of the equation. The right side is easy; when cubed it becomes just y.
    The left side requires some care, because you're multiplying (2y2 - y)(2y2 - y)(2y2 - y). When you're done, the highest degree term will be 8y6. This might turn out to be a messy problem, since you'll be needing to factor a 6th degree polynomial to find the intersection point(s) - I believe there are two.
  4. Feb 5, 2010 #3
    Okay so after I cubed both sides I get:
    8y6 - 12y5 - 2y4 - y3 - y =0
    Then I factor out a y:
    y(8y5 - 12y4 - 2y3 - y2 - 1) = 0
    How do I factor now..? Was there some way to check easier with ration roots theorem?
  5. Feb 5, 2010 #4
    Mentallic
    Yes the other root is rational so use the theorem to find it.
    It would have saved you a lot of hassle cubing and even makes finding the other root besides y=0 much easier if you substituted [itex]y=x^3[/itex] into [itex]x+y=2y^2[/itex]. You will quickly and easily get [itex]x+x^3=2x^6[/itex].
