Is This Video of a Fake Cavendish Experiment Really Accurate?
  • Thread starter rockyshephear
  • Tags
    Experiments
In summary, the conversation revolves around a video on YouTube showing a demonstration of the Cavendish experiment, which measures the gravitational forces between two masses. There is skepticism about the accuracy of the demonstration, with concerns raised about the setup and the possibility of outside influences affecting the results. The conversation also touches on the original experiment conducted by Cavendish and how it differs from the YouTube video. Ultimately, the physicists in the conversation agree that the video is not a reliable source and that proper conditions and equipment are necessary for an accurate demonstration of the Cavendish experiment.
rockyshephear
232
I've seen redone Cavendish experiments on YouTube where the 2 lead spheres suspended from a latter rotate to to slightly larger lead stationary bricks. The spheres rotate and touch the bricks. This must be fake. Gravity is just not that strong a force. My guess is that equilibrium is attained by a deflection on both parts in the hudreds of thousanths of an inch or less.
Would my critique be correct?
Squarkman
I'm inclined to agree with you. In the original experiment, Cavendish measured torsional forces, not displacement--I don't believe there was sufficient displacement to be measure with any accuracy, certainly not that that time. Never mind enough you could actually watch.
Here's the actual video and all comments. It's so fake.
I would think that before you call someone a liar, you'd have a stronger case than "It's so fake".
You didn't mention what video, so let's consider http://www.youtube.com/watch?v=QquPcufXDUo":
https://www.youtube.com/watch?v=QquPcufXDUo
Now, how long do we expect it takes the test weights to "fall" towards the large ones? For spheres near their surfaces, [itex] g \sim \rho R[/itex] and [itex]t \sim 1/\sqrt{g}[/itex] so [itex]t \sim 1/\sqrt{\rho R}[/itex]. A 3 pound ball of lead has density twice that of the Earth and a radius 200 million times smaller. So, you'd expect it to take 10,000 times longer for it to fall.
On earth, it takes an object about 1/7 of a second to fall 4 inches. So on the video you would expect it to take about half an hour. It takes 40 minutes.
I guess you've made a believer out of me but I'm still have a few concerns. What about all of the much more massive object just a bit farther away that the lead sinkers that would tend to pull the rotating masses in the opposite direction. This demonstration was not done in outer space away from other planets, masses, etc.
I'm going to try the same experiement on ice and see if a huge lead ball will drag a smaller lead ball toward it on a slick chunk of ice.
You can't really have a torsional force in a wire without a displacement of the thing on the end of the wire.
Cavendish hung a mirror on the wire, by looking at a scale reflected in the mirror he was able to see a very small rotation of the wire caused by the real physical motion of the masses on the end of it.
For the video - you would need whatever the beam is balanced on to be seriously low friction and a bubble level like that is nowhere near accurate enough to say that it is flat. To convince anyone you should move the lead blocks to the other side and have them move the bar back in the same time.
The torsion would have been much greater had he set it up with two spheres which rotate by the torsion as in your demonstration. Why didn't he do that. Then you'd get a greater accuracy, right?
Except the Cavendish balls aren't in freefall, they have to act against the torsion of the suspending line, which increases linearly with angular displacement. Given that the gravitational force between the masses amounts to on the order of 10-7 N, I can't see how it can act through an arc of the size shown in the video. Consider that in Cavendish's original experiment, the linear displacement of the end of the rod the moveable masses were suspended from was only .16" according to the Wiki link on his experiment. And that was performed ounder much, much more rigorous conditions than shown in the YouTube vid.
Sorry, but YouTube videos are not ever to be taken at face value. Ever.
Note that I said "sufficient displacement."
So negitron, you are debunking the YouTube video?
I am.
As am I! Thank you!
I am unable to see a link to the video mentioned by the OP, but I have no reason to believe that a homemade demonstration would not be possible. rockyshephear and negitron, do you also believe that this one is fake?
http://www.fourmilab.ch/gravitation/foobar/
I'll review it and get back to you. Any of you other physicists want to chime in on this one? Should be terribly easy question for you!
I would like to say that I don't disagree that everything in the universe attracts everything else. I am just skeptical that demonstrations like we are discussing can create near frictionless environments to demonstrate their point. I am positive if a lead sphere 100 pounds we 10 feet from a 1 oz lead ball in a universe where there were no other masses, the object would eventually come in contact with the larger sphere. No doubt whatsoever. I just don't see how a home-made setup can reduce the effects of friction, create such delicate balance required, etc to successfully assimlate the 'out in space' setup I just described.
The example in TurtleMeister's post is certainly possible. We did an undergrad demonstration that is very similair, although without the water brake because to actualy measure G you need the stiffness of the wire and so it has to oscillate freely without the large masses present.
The first video looked like the beam was sitting on a pad of something - but if that was just a water brake as in the fourmilab one then it looks right.
Good point; typically you'd have to take into account the torsion coefficient of the wire which gives it a 'natural oscillation'...and since you do not know that value in the 'hanging thread' experiments, one cannot make an accurate prediction...meaning you cannot make an acceleration prediction in favor of OR AGAINST the video without knowing the torsion coefficient of the hanging wire (thread).
As 'mgb phys' pointed out above, measurements need to be taken in free oscillation first (without mass attractors) in order to obtain the natural oscillation. That is what Cavendish did, and then, if I'm not mistaken, he took the measurements with mass attraction while it was still oscillating, and then compared the difference in the oscillation displacements, which is where the .16'' came from.
This video here is probably better because it shows clearly the oscillation (in time lapse video).
http://www.fourmilab.ch/gravitation/foobar/figures/movie-1.mov
Creator
Hey folks, this is my first visit and post on these forums. I hope no one minds that I dig up this old thread. I found it while doing some searches on fake Cavendish experiment videos. I've seen several videos on Youtube including the ones here that show dramatic visual displacements in a short amount of time. I was skeptical, as most seem to be here. I decided to do some experimenting of my own, and I whipped up a crude torsion balance using fishing line, a wooden dowel, large lead sinkers (just guessing they are about 1/4 kg) on the end of the dowel and weights (15 pounders) from my weight bench. I hung the balance from my ceiling in the hallway so the balance was just above the floor.
It took about an hour for the system to settle, apparently the fishing line had some twists in it. I did not use any dampener (water brake). When I positioned the large masses near the balance, I got about 1 cm of displacement in about 1 minute. I was shocked! I thought that surely this was due to some static charges. However, my experience with pith balls in electrostatics tells me that when contact was made, there should be some repulsion, but that didn't happen, the small and large masses remained in contact. I could then easily reverse the system and again got about 1 cm of displacement in about 1 minute time (should happen twice as fast right, but I wasn't timing anything). Maybe the use of a really long fishing line, from my ceiling to my floor, means that there is very little torque needed in twisting the fishing line? What do you folks think about that?
Oh, by the way, I'm a high school physics/mathematics teacher.
Welcome to PF Broz. I never doubted the fourmilab video. I'm not saying I believe everything I see on Youtube. But this one seemed completely plausible to me. Very good that you did your own experiment. I've thought about doing it myself. But the degree of sensitivity I would like to achieve would be very difficult for an amateur with limited resources. If you're interested in gravity and torsion balances then you may find these links interesting.
http://www.npl.washington.edu/eotwash/intro/intro.html
http://www.physics.uci.edu/gravity/
Thanks for the links TurtleMeister. One thing I was thinking about was the amount of jerk involved. Normally when discussing gravity we take the force to be a constant for our location. However with these balances, the jerk present would seem to be significant. For instance, if my large masses were just 1 cm from the smaller masses and the smaller masses moved just 0.5 cm, then the force of gravity has quadrupled. Of course the effects of static charges would be the same. In my experiment, it started very slowly, then it seemed the amount of acceleration was increasing.
Yes, the jerk is greater because that .5 cm is a much, much greater percentage of "r" than it would be for the earth. Using a damper should help with that.
What is a "Fake Cavendish experiment"?
A "Fake Cavendish experiment" is a scientific experiment that is designed to mimic the famous Cavendish experiment, which was conducted by Henry Cavendish in 1797 to measure the gravitational constant. The purpose of a "Fake Cavendish experiment" is typically to test the accuracy of modern equipment and techniques used in measuring gravitational forces.
Why would someone conduct a "Fake Cavendish experiment"?
There are a few reasons why someone might conduct a "Fake Cavendish experiment." One reason is to verify the accuracy and precision of modern equipment and techniques used in measuring gravitational forces. Another reason is to test alternative theories of gravity that differ from the traditional Newtonian theory used in the original Cavendish experiment.
How does a "Fake Cavendish experiment" differ from the original Cavendish experiment?
A "Fake Cavendish experiment" typically differs from the original Cavendish experiment in a few ways. First, modern equipment and techniques are used instead of the original 18th-century equipment. Second, the experiment may be conducted in a different location or under different conditions. And third, the purpose and goals of the experiment may differ from those of the original Cavendish experiment.
What are the challenges of conducting a "Fake Cavendish experiment"?
One of the main challenges of conducting a "Fake Cavendish experiment" is ensuring that the modern equipment and techniques used are accurate and precise enough to produce reliable results. Additionally, the experiment may need to be conducted in a controlled environment to minimize external factors that could affect the results. Finally, the experiment may require a significant amount of time, resources, and expertise to set up and conduct properly.
What are the potential implications of "Fake Cavendish experiments" on our understanding of gravity?
The potential implications of "Fake Cavendish experiments" on our understanding of gravity are significant. By testing alternative theories of gravity or verifying the accuracy of modern equipment and techniques, these experiments can help scientists refine and improve our understanding of the fundamental force of gravity. They may also lead to new discoveries or insights into the nature of gravity and its effects on the universe.
