Fall with drag
  • Thread starter luckis11
x’’(t)=g-Fd/m=(9.81metres/sec^2)-(k/m)(x’(t))
where x''(t)=du/dt and x'(t)=u=dx/dt
I enter this at http://www.wolframalpha.com/input/?i=
and I get the solution x(t)= -(c1me^(-kt/m))/k+c2+9.81(m/k)t
But
x(t=0)=0
x’(t=0)=0
x(t=0)=c1+c2
x’(t=0)=c1-c2
=>c1=c2=0
=>x(t)=9.81(m/k)t
and this says that it reached terminal speed right from the start of the fall, and it is not the solution mentioned at H.Young p.126. Where's the mistake?
Answers and Replies
First of all, x(t)=9.81(m/k)t is totally wrong, because it states that the velocity is constant, which means that the acceleration is zero.
Here is the solution:
Set y=x', then you have the following 1st order eqn:
y'+(k/m)*y=g => y' / (g-(k/m)y)=1 => y=(m/k)*(g-c1*exp(-k*t/m)), where c1 is constant.
Thus, x'=(m/k)*(g-c1*exp(-k*t/m))=> x=(m/k)*g*t-(m/k)^2*exp(-k*t/m)+c2
I assume that at t=0, x'=0 =>c1=g
and at t=0, x=0 => c2=(m/k)^2
For the terminal velocity, you need to have x''=0 ==> g-(k/m)x'=0, which gives t->oo
What are the initial conditions?
Greatfull for your will to help me, but I did not ask for the correct solution. The correct solution is supposed to be H.Young's p.126, which I have it. I asked where is the mistake in the formulations I stated.
I made a mistake at my previous post, I edited and corrected it now, read it again if you want. I missed to mention that the initial conditions are:
x(t=0)=0, x’(t=0)=0.
Is the mistake that the
x(t=0)=c1+c2
x’(t=0)=c1-c2
is wrong? I was told in this forum that this is so. If it is wrong then how am I supposed to calculate c1 and c2 when I am given a 2nd order dif. eq. solution by the calculator which contains c1 and c2?
Well, you have made several mistakes:
x(t=0)=0 does not give you c1+c2=0, but -c1*(m/k)+c2=0
also x'(t=0)=c1+9.81(m/k)
I was told or thought I was told that in any case:
x(t=0)=c1+c2, x’(t=0)=c1-c2
thus since x(t=0)=0, x’(t=0)=0,
it is c1+c2=0, c1-c2=0,
thus c1=c2=0.
So I guess from what you now said, this is wrong. And my question is, what is the correct procedure to find c1 and c2 when I see a 2nd order dif. eq. solution at the calculator of the form:
x(t)=(here there are c1 and c2).
Have you taken any course on differential equations before?
Anyway,
you have the following expression:
as you can see, "t" appears on both sides of the equation.
The first initial condition states that x(t=0)=0. Therefore, in the above equation set t=0. You also know that x(t=0)=0, which means that the left hand side of the eqn is 0. Thus you get
0=-(c1m)/k+c2
In order to apply the 2nd initial condition, you need to differentiate the equation with respect to t. Then, as before you set t=0, and you know that the left hand side of the new equation is 0. Thus,
x'(t)=c1e^(-kt/m)+9.81(m/k)
and x'(t=0)=0 => 0=c1+9.81(m/k)
Greatfull.:smile:
Related Threads on Fall with drag
  • Last Post
  • Last Post
  • Last Post
  • Last Post
