Falling Object
  • Thread starter maca_404
A helicopter is ascending vertically with a velocity of 12.5ms^-1. At a height of 120m above the ground a package is dropped out the door.
How long does it take for the package to reach the ground ?.
The attempt at a solution
I know
U = 12.5ms
A = -9.8ms
V = 0ms
S = 120m
Used t = v-u/a
T = 1.27 Seconds - the time it takes the object to stop ascending
Then used s = ut + .5 at^2 to find distance traveled
S = 7.97 meters
Adding this to the original height of 120m to get 127.97m
So now I have:
U = 0
A = 9.8ms
S = 127.97m
Use v^2 = u^2+2as to calculate the velocity after t
V = 50
Use V - U/A to get time
T = 5.1
Now I added the ascent and decent time to get total time before it hits the grounds
Total Time = 6.37 Seconds
Could someone look over this for me and tell me if I am even close to the correct answer ?.
Any help would be greatly appreciated
Answers and Replies
s=ut-0.5at^2
S is not a distance traveled but the displacement.
It is it's position with respect to the initial location.
tiny-tim
25,832
251
hi maca_404! :smile:
U = 12.5ms
A = -9.8ms
V = 0ms
S = 120m
no, V is not 0, is it? :redface:
I had V as the velocity after t as it is ascending I assume it would need to be a two part calculations. The first when the object is ascending and being slowed by gravity at 9.8ms till its final velocity is 0 hence the V = 0 at the beginning. Then a second calculations starting from a zero velocity and then accelerating at 9.8ms towards earth. Is this not the correct procedure and can this be done with just one equation ?.
tiny-tim
25,832
251
Thank you for the replies, I am more than a bit confused now I use this ballistic calculator online http://www.convertalot.com/ballistic_trajectory_calculator.html
Entering a initial velocity of 12.5ms and a starting height of 120m and a angle of 90Deg straight up the resulting answer is the same as I obtained originally.
Is my answer incorrect ?. Or am I just going about it the wrong way ?
Thanks Again
tiny-tim
25,832
251
i didn't check your original answer, as soon as i saw that you'd started the wrong way i stopped reading
your answer looks correct, but you won't get many marks in the exam for doing all that unnecessary work :redface:
try it the short way
Related Threads on Falling Object
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
