Speed of Stick's CM Just Before Impacting Ice
  • Thread starter toothpaste666
  • Tags
    Ice Speed
In summary: None of the solutions includes the normal force, torque, or angular acceleration. (Unless, of course, that I missed something, which I'm quite good at doing.) Yes, you are correct. The solutions assume that the stick remains in contact with the ice until the center of mass reaches the ice. This is a simplification, as the stick may lose contact with the ice before the center of mass reaches it. In that case, the motion would be different and would require taking into account the normal force, torque, and angular acceleration.
toothpaste666
516
A thin stick of length L is balanced vertically on frictionless ice. It then tips over and falls. How fast is the center of mass of the stick moving just before it hits the ice?
using energy:
[itex] I = \frac{1}{3}mL^2 [/itex]
[itex] .5Iω^2 = mgh [/itex]
[itex] .5Iω^2 = mg(.5L) [/itex]
[itex] Iω^2 = mgL [/itex]
[itex] (\frac{1}{3}mL^2) ω^2 = mgL [/itex]
[itex] (\frac{L}{3}) ω^2 = g [/itex]
[itex] ω^2 = (\frac{3g}{L}) [/itex]
[itex] ω = (\frac{3g}{L})^{\frac{1}{2}} [/itex]
That all looks good. I would convert from angular speed to linear speed though.
so
v=Rω
[itex] v = L (\frac{3g}{L})^\frac{1}{2} [/itex]
[itex] v = (3Lg)^\frac{1}{2} [/itex]
Be careful when converting - the question asks how fast the center of mass (not the edge) of the stick is moving.
oh right ..
[itex] v = \frac{L}{2} (\frac{3g}{L})^\frac{1}{2} [/itex]
[itex] v = \frac{1}{2}(3Lg)^\frac{1}{2} [/itex]
toothpaste666 said:
using energy:
This doesn't look alright .The lower tip of the rod is not fixed which means the rod is not in pure rotation about the lower end point .The motion of the stick can be thought of as translation of CM+rotation about the CM .
Your approach would have been correct if the lower end point had been pivoted.
Surprisingly the end result in post#5 looks correct .
using energy:
There's something else. The stick is on frictionless ice. That makes a difference compared to what it would be if the stick were on solid ground.
It means the stick does not pivot on its bottom, on the ground. Instead, the bottom end of the stick slides along the ground. Rotationally speaking, the stick pivots at its center! You'll need a different formula for the stick's moment of inertia.
so i should use 1/12 instead of 1/3?
I think so. Do you concur? (Do you understand why I would use 1/12 instead of 1/3?)
because its rotating about the CM and not the tip? which is also why I have to make R = L/2 instead of L?
[itex] I = \frac{1}{12}mL^2 [/itex]
[itex] (\frac{1}{12}mL^2) ω^2 = mgL [/itex]
[itex] (\frac{L}{12}) ω^2 = g [/itex]
[itex] ω^2 = (\frac{12g}{L}) [/itex]
[itex] ω = (\frac{12g}{L})^{\frac{1}{2}} [/itex]
then when converting:
v= Rω
[itex] v = \frac{L}{2} (\frac{12g}{L})^{\frac{1}{2}} [/itex]
[itex] v = \frac{1}{2} (12gL)^{\frac{1}{2}} [/itex]
As Tanya said, "The motion of the stick can be thought of as translation of CM+rotation about the CM."
You've taken care of the KE due to rotation about the CM, but you have not yet included the KE due to translation of the CM.
oh I see so not all of its energy is put into rotating because some of it needs to be used for it to slide?
so it would be
[itex] mgh = .5Iω^2 + .5mv^2 [/itex]
so i should make it so that both velocities are in terms of v and not ω?
[itex] mgh = .5I(\frac{v}{r})^2 + .5mv^2 [/itex]
[itex] mgh = .5I(\frac{v}{\frac{L}{2}})^2 + .5mv^2 [/itex]
[itex] mgh = .5I(\frac{2v}{L})^2 + .5mv^2 [/itex]
[itex] mgh = .5(\frac{1}{12}mL^2)(\frac{4v^2}{L^2})+ .5mv^2 [/itex][itex] mgh = .5(\frac{1}{12}m)(4v^2)+ .5mv^2 [/itex][itex] mg(.5L) = .5(\frac{1}{3}m)(v^2)+ .5mv^2 [/itex][itex] gL = (\frac{1}{3})(v^2)+ v^2 [/itex]
[itex] gL = (\frac{4}{3})(v^2) [/itex]
[itex] v = (\frac{3}{4}gL)^\frac{1}{2} [/itex]
There you go. :approve: I think that's right.
Likes 1 person
That looks good.
It's important to understand why ##v_{cm} = \omega \frac{L}{2}## at the instant the stick strikes the ice. This relation is not true at other times.
Likes 2 people
Hello TSny
Please check my understanding.
Because as the stick is about to strike the ice ,it becomes horizontal and the speed of the lower tip reduces to zero .Hence the lower tip may be treated as an instantaneous axis of rotation .Or in other words the stick is in pure rotation about the lower tip just as it is about to strike the ice .Hence the relation vcm = ωL/2 is applicable .At other times the lower tip is moving so the relation vcm = ωL/2 doesn't hold .
Is it correct ?
Likes 1 person
Is it correct ?
Yes, that's correct.
A related problem came up recently with a cube instead of a stick. https://www.physicsforums.com/showthread.php?t=750988
Here the instantaneous axis of rotation is not on the frictionless surface at the final position.
Likes 1 person
I'm just speculating here.
It seems these solutions are assuming that the end of the stick which is initially in contact with the ice -- they're assuming that end remains in contact with the ice.
I'm thinking that might not be the case.
Thanks...
Yes, I agree that's a valid concern. I investigated this some years ago and managed to show that it does stay in contact with the ice, but I couldn't see a trivial way to show it.
(I believe it will become airborne if there's sufficient friction.)
Thanks haruspex. Nice to confirm that I wasn't completely off base!
It seems to me that if you do this with normal force included, you can see if the normal force ever goes negative. (I don't know if this is trivial. ) :-)
I recall that if you have a ladder slide down a wall with both vertical and horizontal surfaces frictionless, the ladder will lose contact will one or both surfaces.
thank you all!
What is the "speed of stick's CM just before impacting ice"?
The "speed of stick's CM just before impacting ice" refers to the velocity of the center of mass of a stick right before it makes contact with the surface of ice.
Why is the "speed of stick's CM just before impacting ice" important to study?
The "speed of stick's CM just before impacting ice" is important to study because it plays a crucial role in understanding the physics of collisions between objects and surfaces, which has practical applications in fields such as sports and engineering.
How is the "speed of stick's CM just before impacting ice" measured?
The "speed of stick's CM just before impacting ice" can be measured using various methods, such as using high-speed cameras to track the motion of the stick, or using sensors to measure the acceleration of the stick.
What factors can affect the "speed of stick's CM just before impacting ice"?
The "speed of stick's CM just before impacting ice" can be affected by factors such as the initial velocity of the stick, the angle at which it makes contact with the ice, and the surface properties of the ice (e.g. friction, temperature).
How can knowledge of the "speed of stick's CM just before impacting ice" be applied in real-life situations?
Knowledge of the "speed of stick's CM just before impacting ice" can be applied in various situations, such as improving the design and performance of equipment used in sports involving ice, or analyzing and predicting the outcome of collisions between objects and ice surfaces in engineering applications.
